More details on CSV2
Hi all,
I read the ARM  “Spectre BHB: Speculative Target Reuse Attacks” white paper and I wanted to ask for clarification on how CSV2 works.
From my understanding, CSV2 adds process identifiers to each entry so that a different context without the same ID cannot use an entry that does not match.
So on prediction, the IDs must match for the entry to be used; otherwise, the branch is treated as not taken.
However, on update, the ID check does not apply, and a new entry can overwrite an existing one even if the IDs differ.
Is this understanding correct? Any additional clarification would be appreciated.
  • So on prediction, the IDs must match for the entry to be used; otherwise, the branch is treated as not taken.
    It's not using the entry from the other context to make the decision in this context.  Where there's no (suitable) entry, a design might always predict not-taken.  Or always taken.  Or some other scheme.  The point is that the other context isn't influencing the decision.
    This is the same as with other caches.  An access from Non-secure state cannot hit on a cache line that contains a Secure physical address - but it could cause it to be evicted to make way for something that Non-secure state needs.
