CMSDK Compile Error for Cortex-M0
when i ran the tb_cmsdk_mcu.v it outputs the following error
"ERROR: [Synth 8-3391] Unable to infer a block/distributed RAM for 'ram_data_reg' because the memory pattern used is not supported. Failed to dissolve the memory into bits because the number of bits (524288) is too large. Use 'set_param synth.elaboration.rodinMoreOptions {rt::set_parameter dissolveMemorySizeLimit 524288}' to allow the memory to be dissolved into individual bits"
are there any solution of the related error and how to solve them?
