Can Cross Trigger Configure Multiple Cores to Halt Simultaneously in Self-Hosted Debug?
In self-hosted debug scenarios, is it feasible to configure the cross-trigger pathway (via CTI/CTM) to halt multiple cores simultaneously? Our experimental results on ARMv9 show that configuring CTI triggers can indeed force cores to stop execution. However, we are uncertain whether this state qualifies as a "halt" (i.e., cores entering debug state), because: According to protocol specifications, self-hosted debug operates through debug exceptions (e.g., breakpoints triggering software handlers), without requiring cores to enter a hardware-controlled debug state.
  • Hi
    My name is Stephen and I work at Arm.
    Yes, CTI/CTM can be used to halt multiple cores simultaneously.  Halting debug is intended to be handled by an external debugger (e.g. Arm DS Debugger & DSTREAM-ST) because a halted core cannot restart itself without some outside intervention.
    By contrast, self-hosted debug is usually implemented through the generation and handling of debug exceptions, and does not normally require entering the "halt" state.  See:
    https://developer.arm.com/documentation/102120/0101/AArch64-debug
    If you need more information, I suggest you "Open a Support Case" using the link at the bottom of this web page.
    Hope this helps
    Stephen
