Question about AMBA CHI_C2C spec.A credit
Hi ARM,
  In AMBA CHI_C2C spec, flow control credit is independent for different message class, but dose not distinguish message type(Short long)
  So does it mean than 1 credit is represent for a corespoding C2C message not care message type? (ReqL/S, DataS/L, Resp/Resp2 consume both 1 corespoding credit?)
  The credit base flow control is work for preventing C2C RX buffer from overflow. So does it mean one Short/Long type message、Resp/Resp2 consume the same C2C RX buffer space?
Best Regards.
  • Hello Jinyu,
    Your understanding is correct that crediting in C2C is essentially done per protocol message class, rather than per specific message type. And so there is a degree of abstraction from the packing into granules.
    Coming to your specific examples:
    ReqS/ReqL - Both message types require 1 REQ credit. Note that the amount of RX storage space that this will translate to depends on a number of on-chip payload and opcode/flow properties.
    DataS/DataL - Both message types require 1 DAT credit, similarly to above.
    Resp/Resp2 - One RSP credit is required for each *protocol* response. Therefore, Resp C2C message type (MsgType=0b0100) requires 1 RSP credit and Resp2 C2C message type (MsgType=0b0101) requires 2 RSP credits (because it contains two protocol responses.
    Hope this helps.
    Simone
