I am integrating an M55 into a subsystem with interrupts, and have enabled the IWIC (internal wakeup interrupt controller).
I understand that this will wake up the M55 from sleep upon interrupt. If the main CLKIN to M55 is gated (gater controlled by a q-channel clock controller), do I need to connect a non-gated clock to the IWICCLK input in order to wake up the M55 and allow it to set the clkinqactive to the clock controller?
