Typical instruction per cycle in A53 CPU.
I program A53 without OS for some arithmetic operations.
The task generates 2K 32b numbers using polynomial of CRC32, store, move from/to and compares different portions of 32b numbers in L1 data cache, continuously.
Right now I get a instruction per cycle of 1.05 in Xilinx's Zynq Ultrascale device. What is a guesstimated IPC for such workloads?
I am pondering whether there are room for improvement from 1.05.
I understand the A53 has two instruction decoders, would that mean the peak IPC would be 2?
Thank you.
  • Yes, the peak IPC would be two and the core can dual issue most arithmetic/logic instructions. There are a few types of instruction with only a single backend which can only issue a single operation per clock of that type. There is a single load/store pipe, only one integer pipe has a multiplier, and there is only a single vector pipe for NEON.
    The main thing to be aware of when optimizing for A53 is that it's an in-order pipeline, so much more sensitive to instruction ordering and load-use time than the bigger out-of-order cores.
    I can't find a version of the software optimization guide for Cortex-A53, but here is the one for Cortex-A55 which should be similar in terms of broad concepts:
    developer.arm.com/.../
    HTH,
    Pete
  • Thank you Pete.
    A55 is very similar to A53 I know so the opt guide would applicable to A53 too.
