I am working on an Intel Cyclone V SoC ARM Cortex A9 Dual Core setup and aiming to execute two distinct codes on Core 0 and Core 1 in bare-metal mode. While I've successfully executed this setup using JTAG debugging, where I sequentially debugged Core 0 followed by Core 1 after taking it out of reset, I'm encountering a problem when attempting to run both cores via QSPI flash.
Despite combining both programs into a single image file, Core 1 fails to execute as expected. In the linker/scat file, Core 0's entry point is specified as 0x60000, and Core 1's entry point is set to 0x9fff0. **However, upon execution, Core 0 behaves correctly, while Core 1's program counter jumps to 0xFEBAF5E8 instead of its designated entry point.**
I have also asked in the intel community forum but no reasonable response. Your insights or suggestions on resolving this discrepancy would be greatly appreciated.
Thank you!
**Core 0 firmware and linker file**
```#include "HAL/hal_common.h"#include "HAL/hal_timer.h"#include "alt_mmu.h"#include "alt_cache.h"//#include "hwlib.h"
typedef int32_t ALT_STATUS_CODE;
#define ARRAY_COUNT(array) (sizeof(array) / sizeof(array[0]))
#define RSTMGR_MPUMODRST_OFFSET 0x10 // offset#define RSTMGR_MPUMODRST_ADDR (0xFFD05000 + RSTMGR_MPUMODRST_OFFSET)
#define RSTMGR_CPU1_ADDR 0xFFD080C4void main(void){ // Initialize HAL HAL_Init(); TIM_Init(); TIM_Preset(); volatile uint32_t* cpu1startaddr = (uint32_t*)0xFFD080C4; *cpu1startaddr = 0x100000 ; // cpu1 reset exception address 0x160010
//*pPreLoaderStateReg = BL_CONFIG_PRELOADER_STATE_VALID; uint32_t reg_val = *(volatile uint32_t *)RSTMGR_MPUMODRST_ADDR; reg_val &= ALT_RSTMGR_MPUMODRST_CPU1_CLR_MSK; *(volatile uint32_t *)RSTMGR_MPUMODRST_ADDR = reg_val; // taking core 1 out of reset from core 0
while (1) {
// functionality we want to achieve from core 0 also it take core 1 out of reset already
**Scat file** ```SDRAM 0x00060000 0x40000;0x40000; 0x62250{ ; Vector Table VECTORS +0 { * (VECTORS, +FIRST) } ; Application Code APP_CODE +0 { * (+RO, +RW, +ZI) } ; 256 Byte stack ARM_LIB_STACK +0 EMPTY 0x0100 { } ; 64kB Heap (not used) ARM_LIB_HEAP +0 EMPTY 0x010000 { } }
**Core 1 firmware and linker file**
//#include "HAL/hal_timer.h"
/** * Bootloader Main Function */void main(void){ HAL_Init();// TIM_Init();// TIM_Preset(); uint32_t ii=0; uint8_t led_status=0; while (1) { // functionality we want to achieve from core 1}}
**Scat file**
```SDRAM_CORE1 0x9fff0 0x6c960
{ ; Vector Table VECTORS +0 { * (VECTORS, +FIRST) } ; Application Code APP_CODE +0 { * (+RO, +RW, +ZI) } ; 256 Byte stack ARM_LIB_STACK +0 EMPTY 0x0100 { } ; 64kB Heap (not used) ARM_LIB_HEAP +0 EMPTY 0x010000 { } }```
