AXI Locked Write and Lock Scope
Hi All,
       1)  1st master is doing locked write transfer to 'X location after that, Can 2nd master initiate a read normal transfer for 'Y address in same slave? . And still unlocked transfer is not initiated by the 1st master?.
       2)  Locked transfer is for Bus channel or specific Slave region?
Regards,
Deepak
  • From the AMBA AXI spec:
    When the ARLOCK[1:0] or AWLOCK[1:0] signals for a transaction show that it is a locked transfer then the interconnect must ensure that only that master is allowed access to the slave region until an unlocked transfer from the same master completes. The arbiter within the interconnect is used to enforce this restriction.
  • Hi Martin,
      Thank you, I have got more clear about LOCKED access. I have ohter questions about LOCKED transfer.
    • 1st master is initiate locked write transfer to 'X location after that, Can Same master initiate a read locked/normal transfer for 'Y (different) address in same slave before unlocked transfer is issued by same master?.
    • To complete the 'Exclusive operation, master should initiate Exclusive read followed by Exclusive write  transfer so, To complete Locked transfer is there any read followed by write sequence must be initiate?
    Regards,
    deepak
