Hi all,
I have some questions about branch instructions and TrustZone, not sure if here is the right place to post them.
I am using cortex M23, and I debug with Keil MDK.
I don't know if there is any limitation on branch instructions (B,BX, BL,BLX,BXNS,BLXNS). But here it says when processor is in non-secure state, the LSB of address shouldn't be 0, otherwise there will be hardfault.
Does any one know why is it?
I am writing a non-secure software, so I did not enable the compiler TrustZone option (-mcmse) in this project. And I am using ARM compiler C library for startup and initialization.
In the assembly, there is one line
_main_scatterload 0x12000064: f000f84c ..L. BL __scatterload ; 0x12000100
After this line the processor goes into secure handler state. So I guess BL & B have the same limitation like BLX & BX? It triggers a hardfault when the LSB of address is 0?
I don't think this is true. Because assembly is generated by compiler. If I cannot use 0x12000100 as destination, the compiler should know.
To provide more information, I put the assembly of __scatterload:
__scatterload __scatterload_rt2 0x12000100: 4c06 .L LDR r4,[pc,#24] ; [0x1200011c] = 0x12000140 0x12000102: 2501 .% MOVS r5,#1 0x12000104: 4e06 .N LDR r6,[pc,#24] ; [0x12000120] = 0x12000150 0x12000106: e005 .. B 0x12000114 ; __scatterload + 20 0x12000108: 68e3 .h LDR r3,[r4,#0xc] 0x1200010a: cc07 .. LDM r4!,{r0-r2} 0x1200010c: 432b +C ORRS r3,r3,r5 0x1200010e: 3c0c .< SUBS r4,r4,#0xc 0x12000110: 4798 .G BLX r3 0x12000112: 3410 .4 ADDS r4,r4,#0x10 0x12000114: 42b4 .B CMP r4,r6 0x12000116: d3f7 .. BCC 0x12000108 ; __scatterload + 8 0x12000118: f7ffffa6 .... BL __main_after_scatterload ; 0x12000068
Thanks,
Hilda
