Possible Documentation error in KBA Article ID: KA001775?
I was going through KBA Article ID: KA001775, and in the answer to the question "Will the DMA carry out byte-sized bursts if the width is defined as byte wide, and INCR type bursts if burst length is defined as 4,8 etc?"  in the second para it is mentioned:
"For example, if the width is 8-bits and a DMAC SINGLE request is made, then the DMA will carry out a single transfer of 8-bits.
If the width is say 16- bits and source burst size is 256, and the DMAC BURST request (and perhaps DMAC SINGLE request) is used, then the DMAC will carry out 256 8-bit transfers."
Shouldn't the DMAC carry out 256 16-bit transfers?
Thanks in advance,
Gautam.
