PMU event count register PMEVCNTR<n> alway is 0
Hello ,all。
I am now learning the use of PMU. But when I do this, PMXEVCNTR_EL0 is always 0. PMCCNTR_EL0 is normal
Device: cortex-a72(ARMV8.2-A)
System: Rtos(ThreadX)
step
    1. Configure PMCNTENSET_EL0 to enable Cycle counter
    2. Configure pmuserenr_el0(en).
    3. Configure PMSELR_EL0 to select count.
    4. Configure PMXEVTYPER_EL0 and set events.
    5. Configure PMCNTENSET_EL0 to enable Cycle counter and event counter
    6. Configure PMCR_EL0 and enable PMU, reset Cycle counter, and event counter
    7. Run the test code
    8 Stop the PMUs
    9. Configure PMSELR_EL0 to select count,
    10 Read PMXEVCNTR_EL0 and PMCCNTR_EL0.
result
     PMXEVCNTR_EL0 is 0, and PMCCNTR_EL0 is normal
I have checked the value of the relevant register, and the value of the register is indeed changed. I have checked the Arm® Cortex®-A76 Core Technical Reference Manual, and all the events set are also supported.
Note: The code is running in firmware.
code:
void ARM_PMU_Start(void)
// PMU->CTRL |= PMU_CTRL_ENABLE_Msk;
int val=0;
__asm__ volatile("msr pmuserenr_el0, %0" :: "r" ((1 << 0) | (1 << 2)));
__asm__ volatile("msr PMSELR_EL0, %0" : : "r" (0));
__asm__ volatile("isb" : :);
__asm__ volatile("msr PMXEVTYPER_EL0, %0" : : "r" (0x2));
__asm__ volatile("msr PMSELR_EL0, %0" : : "r" (1));
__asm__ volatile("msr PMXEVTYPER_EL0, %0" : : "r" (0x4));
__asm__ volatile("msr PMSELR_EL0, %0" : : "r" (2));
__asm__ volatile("msr PMXEVTYPER_EL0, %0" : : "r" (0x6));
__asm__ volatile("msr PMCNTENSET_EL0, %0" : : "r" ((7|(1<<31))));
__asm__ volatile("mrs %0, PMCR_EL0" : "=r" (val));
val|=1 << 0;
val|=1 << 1;
val|=1 << 2;
__asm__ volatile("msr PMCR_EL0, %0" : : "r" (val));
void ARM_PMU_Stop()
int val=0;
__asm__ volatile("mrs %0, pmcr_el0" : "=r" (val));
__asm__ volatile("msr pmcr_el0, %0" : : "r" (val&(~PMU_CTRL_ENABLE_Msk)));
__asm__ volatile("mrs %0, pmccntr_el0" : "=r" (val));
printf("Perf:pmccntr_el0 %d \n",val);
__asm__ volatile("mrs %0, PMXEVCNTR_EL0" : "=r" (val));
printf("Perf:PMXEVCNTR_EL0 %d \n",val);
void Test_PMU()
ARM_PMU_Start();
test_code();//the test code
ARM_PMU_Stop();
