Cortex-M1 Set Initial SP Value and the Reset Value
Hello, I hope someone can help me
I am using a Cortex-M1, and I need to used a external memory from where the program code will be executed. the program code should starts from the address 0xF000 (size 0x8000), and the data will start at 0x20100000 (size 0x8000).
Is it possible to set the Initial SP Value and the Reset Value in ARM assembler at an arbitrary address in memory? When i run the simulation the program is stuck, what i should modified in the startup file ?
Using the dialog for target in Keil
i got the Scatter file
; *** Scatter-Loading Description File generated by uVision ***
LR_IROM1 0x000F0000 0x00008000  {    ; load region size_region
  ER_IROM1 0x000F0000 0x00008000  {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
   .ANY (+XO)
  RW_IRAM1 0x20100000 0x00008000  {  ; RW data
   .ANY (+RW +ZI)
Here is the startup file
;<h> Stack Configuration
;  <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
;</h>
Stack_Size      EQU      0x00000400
                AREA     STACK, NOINIT, READWRITE, ALIGN=3
__stack_limit
Stack_Mem       SPACE    Stack_Size
__initial_sp
;<h> Heap Configuration
;  <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
;</h>
Heap_Size       EQU      0x00000400
                IF       Heap_Size != 0                      ; Heap is provided
                AREA     HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE    Heap_Size
__heap_limit
                ENDIF
                PRESERVE8
                THUMB
; Vector Table Mapped to Address 0 at Reset
                AREA     RESET, DATA, READONLY
                EXPORT   __Vectors
                EXPORT   __Vectors_End
                EXPORT   __Vectors_Size
__Vectors       DCD      __initial_sp                        ;     Top of Stack
                DCD      Reset_Handler                       ;     Reset Handler
                DCD      NMI_Handler                         ; -14 NMI Handler
                DCD      HardFault_Handler                   ; -13 Hard Fault Handler
                DCD      0                                   ;     Reserved
                DCD      0                                   ;     Reserved
                DCD      0                                   ;     Reserved
                DCD      0                                   ;     Reserved
                DCD      0                                   ;     Reserved
                DCD      0                                   ;     Reserved
                DCD      0                                   ;     Reserved
                DCD      SVC_Handler                         ;  -5 SVCall Handler
                DCD      0                                   ;     Reserved
                DCD      0                                   ;     Reserved
                DCD      PendSV_Handler                      ;  -2 PendSV Handler
                DCD      SysTick_Handler                     ;  -1 SysTick Handler
                ; Interrupts
                DCD      UART0_Handler                       ;   0 UART0 Interrupt handler
                DCD      UART1_Handler                       ;   1 UART1 Interrupt handler
                DCD      TIMER0_Handler                      ;   2 TIMER0 Interrupt handler
                DCD      TIMER1_Handler                      ;   3 TIMER1 Interrupt handler
                DCD      GPIO0_Handler                       ;   4 GPIO0 Interrupt handler
                DCD      UARTOVF_Handler                     ;   5 UART0,1 Overflow Interrupt handler
                DCD      RTC_Handler                         ;   6 RTC Interrupt handler
                DCD      I2C_Handler                         ;   7 I2C Interrupt handler
                DCD      CAN_Handler                         ;   8 CAN Interrupt handler
                DCD      ENT_Handler                         ;   9 Ethernet Interrupt handler
				DCD      Interrupt10_Handler                 ;   10 Interrupt 10
				DCD      DTimer_Handler                      ;   11 DualTimer Interrupt handler
				DCD      TRNG_Handler                        ;   12 TRNG Interrupt handler
				DCD      Interrupt13_Handler                 ;   13 Interrupt13 handler
				DCD      Interrupt14_Handler                 ;   14 Interrupt14 handler
				DCD      Interrupt15_Handler                 ;   15 Interrupt15 handler
				DCD      GPIO0_0_Handler                     ;   16 GPIO0_0 Interrupt handler
				DCD      GPIO0_1_Handler                     ;   17 GPIO0_1 Interrupt handler
				DCD      GPIO0_2_Handler                     ;   18 GPIO0_2 Interrupt handler
				DCD      GPIO0_3_Handler                     ;   19 GPIO0_3 Interrupt handler
				DCD      GPIO0_4_Handler                     ;   20 GPIO0_4 Interrupt handler
				DCD      GPIO0_5_Handler                     ;   21 GPIO0_5 Interrupt handler
				DCD      GPIO0_6_Handler                     ;   22 GPIO0_6 Interrupt handler
				DCD      GPIO0_7_Handler                     ;   23 GPIO0_7 Interrupt handler
				DCD      GPIO0_8_Handler                     ;   24 GPIO0_8 Interrupt handler
				DCD      GPIO0_9_Handler                     ;   25 GPIO0_9 Interrupt handler
				DCD      GPIO0_10_Handler                    ;   26 GPIO0_10 Interrupt handler
				DCD      GPIO0_11_Handler                    ;   27 GPIO0_11 Interrupt handler
				DCD      GPIO0_12_Handler                    ;   28 GPIO0_12 Interrupt handler
				DCD      GPIO0_13_Handler                    ;   29 GPIO0_13 Interrupt handler
				DCD      GPIO0_14_Handler                    ;   30 GPIO0_14 Interrupt handler
				DCD      GPIO0_15_Handler                    ;   31 GPIO0_15 Interrupt handler
__Vectors_End
__Vectors_Size  EQU      __Vectors_End - __Vectors
                AREA     |.text|, CODE, READONLY
; Reset Handler
Reset_Handler   PROC
                EXPORT   Reset_Handler             [WEAK]
                IMPORT   SystemInit
                IMPORT   __main
                LDR      R0, =SystemInit
                BLX      R0
                LDR      R0, =__main
                BX       R0
                ENDP
; Macro to define default exception/interrupt handlers.
; Default handler are weak symbols with an endless loop.
; They can be overwritten by real handlers.
                MACRO
                Set_Default_Handler  $Handler_Name
$Handler_Name   PROC
                EXPORT   $Handler_Name             [WEAK]
                B        .
                ENDP
                MEND
; Default exception/interrupt handler
                Set_Default_Handler  NMI_Handler
                Set_Default_Handler  HardFault_Handler
                Set_Default_Handler  SVC_Handler
                Set_Default_Handler  PendSV_Handler
                Set_Default_Handler  SysTick_Handler
                Set_Default_Handler  UART0_Handler
                Set_Default_Handler  UART1_Handler
                Set_Default_Handler  TIMER0_Handler
                Set_Default_Handler  TIMER1_Handler
                Set_Default_Handler  GPIO0_Handler
                Set_Default_Handler  UARTOVF_Handler
                Set_Default_Handler  RTC_Handler
                Set_Default_Handler  I2C_Handler
                Set_Default_Handler  CAN_Handler
                Set_Default_Handler  ENT_Handler
				Set_Default_Handler  Interrupt10_Handler
				Set_Default_Handler  DTimer_Handler
				Set_Default_Handler  TRNG_Handler
				Set_Default_Handler  Interrupt13_Handler
				Set_Default_Handler  Interrupt14_Handler
				Set_Default_Handler  Interrupt15_Handler
				Set_Default_Handler  GPIO0_0_Handler
				Set_Default_Handler  GPIO0_1_Handler
				Set_Default_Handler  GPIO0_2_Handler
				Set_Default_Handler  GPIO0_3_Handler
				Set_Default_Handler  GPIO0_4_Handler
				Set_Default_Handler  GPIO0_5_Handler
				Set_Default_Handler  GPIO0_6_Handler
				Set_Default_Handler  GPIO0_7_Handler
				Set_Default_Handler  GPIO0_8_Handler
				Set_Default_Handler  GPIO0_9_Handler
				Set_Default_Handler  GPIO0_10_Handler
				Set_Default_Handler  GPIO0_11_Handler
				Set_Default_Handler  GPIO0_12_Handler
				Set_Default_Handler  GPIO0_13_Handler
				Set_Default_Handler  GPIO0_14_Handler
				Set_Default_Handler  GPIO0_15_Handler
                ALIGN
; User setup Stack & Heap
                EXPORT   __stack_limit
                EXPORT   __initial_sp
                EXPORT   __heap_base
                EXPORT   __heap_limit
                ENDIF
                END
