Hello everyone!
I am trying writing a module that needs to flush the data cache base on an address range, and I found dcache_clean_inval_poc calls within the arm/include/asm/cacheflush.h, but compiling the kernel for arm64 gives me errors since this function is not exported globally.
I do see on other archteictures implementing flush_dcache_range, such as powerpc. I am curious to see if arm64 already has a function like that and I just missed it? If not, does it need to be implemented? or Is there a reason why that it has not been implemented?
Dear mvcheng,
This function is present since Linux v5.14-rc1
cache.S - arch/arm64/mm/cache.S - Linux source code (v5.14-rc1) - Bootlin
Best Regards,Willy WolffArm Partner Enablement Group
