We know that HTRANS can change from NONSEQ to IDLE during the 2-cycle error response.
We also know that if HTRANS is NONSEQ, it can remain at NONSEQ.
But can HTRANS change from IDLE to NONSEQ?
Yes.
This can happen if the transfer source is ignoring the ERROR response and is just treating it as a wait state. Then the protocol allows HTRANS to change from IDLE to NONSEQ during a waited transfer (see section 3.6.1).
But if HTRANS is NONSEQ or SEQ during the first of the 2-cycle ERROR response, HTRANS must either stay at NONSEQ/SEQ if the transfer source is ignoring the ERROR, or it must change to IDLE if the source decides to cancel the next indicated transfer to respond to the ERROR.
