How to measure program execution time in ARM Cortex-A53 processor?
I was using following method to read clock in cortex-a15:
       static void readticks(unsigned int *result)
            struct timeval t;
            unsigned int cc;
            if (!enabled) {
                // program the performance-counter control-register:
                asm volatile("mcr p15, 0, %0, c9, c12, 0" :: "r"(17));
                //enable all counters
                asm volatile("mcr p15, 0, %0, c9, c12, 1" :: "r"(0x8000000f));
                //Clear overflow.
                asm volatile("mcr p15, 0, %0, c9, c12, 3" :: "r"(0x8000000f));
                enabled = 1;
            asm volatile("mrc p15, 0, %0, c9, c13, 0" : "=r"(cc));
            gettimeofday(&t,(struct timezone *) 0);
            result[0] = cc;
            result[1] = t.tv_usec;
            result[2] = t.tv_sec;
And final performance looks like:
before = readticks()
  foo()
after = readticks()
clock_cycles = after - before.
I want to use same logic in cortex-A53, ARM64 (not aarch32).
I have tried this after following online portals:
        /* All counters, including PMCCNTR_EL0, are disabled/enabled */
            #define QUADD_ARMV8_PMCR_E (1 << 0)
            /* Reset all event counters, not including PMCCNTR_EL0, to 0
        #define QUADD_ARMV8_PMCR_P (1 << 1)
        /* Reset PMCCNTR_EL0 to 0 */
        #define QUADD_ARMV8_PMCR_C (1 << 2)
        /* Clock divider: PMCCNTR_EL0 counts every clock cycle/every 64 clock cycles */
        #define QUADD_ARMV8_PMCR_D (1 << 3)
        /* Export of events is disabled/enabled */
        #define QUADD_ARMV8_PMCR_X (1 << 4)
        /* Disable cycle counter, PMCCNTR_EL0 when event counting is prohibited */
        #define QUADD_ARMV8_PMCR_DP (1 << 5)
        /* Long cycle count enable */
        #define QUADD_ARMV8_PMCR_LC (1 << 6)
    static inline unsigned int armv8_pmu_pmcr_read(void)
            unsigned int val;
        /* Read Performance Monitors Control Register */
        asm volatile("mrs %0, pmcr_el0" : "=r" (val));
        return val;
        static inline void armv8_pmu_pmcr_write(unsigned int val)
        asm volatile("msr pmcr_el0, %0" : :
            "r" (val & QUADD_ARMV8_PMCR_WR_MASK));
        static void enable_all_counters(void)
            unsigned int val;
            /* Enable all counters */
            val = armv8_pmu_pmcr_read();
            val |= QUADD_ARMV8_PMCR_E | QUADD_ARMV8_PMCR_X;
            armv8_pmu_pmcr_write(val);
        static void reset_all_counters(void)
            unsigned int val;
            val |= QUADD_ARMV8_PMCR_P | QUADD_ARMV8_PMCR_C;
      struct timeval t;
      unsigned int cc;
      unsigned int val;
      if (!enabled) {
        reset_all_counters();
        enable_all_counters();
        enabled = 1;
      cc = armv8_pmu_pmcr_read();
      result[0] = cc;
But nothing is working and i am gettin "illegal instruction" error. Can anyone help me to change the above code?
Thanks,
RV
  • This is an EL0 (userspace) app?  If so it's configurable whether the PMU can be accessed at EL0.  Controlled by PMUSERENR_EL0.  It's possible you configured the equivalent (PMUSERENR) on the Cortex-A15 platform, but not on this one.
    Your code snippet doesn't include an ISB instruction.  Changes to context (e.g. enabling the PMU) is not guaranteed to take effect until a context synchronizing event.  If you have access to DS-5, it includes some example bare metal PMU code with the required ISBs.
    One other note, the PMU measure cycles rather than time.  I'm guessing you already know that, but I thought it worth mentioning.
  • @Chris Shore
    mweidmann
    @sujathalakshmi.k
    Please help.
    Yes, its an EL0 app. I am trying to benchmark some algorithms for cortex-a53 and I need clock cycles as benchmark not time. I dont have access to DS-5.
    So I got this from manual that PMCR_EL0, which is 32 bit reg, can be used as performance monitor directly in aarch64. I have changed the readtick function simple like this:
      struct timeval t;
      unsigned int cc;
      unsigned int val;
      if (!enabled) {
        //reset all counters
      asm volatile("msr pmcr_el0, %0" : : "r" (17));
      asm volatile("msr pmcr_el0, %0" : : "r" (0x8000000f));
        enabled = 1;
      asm volatile("mrs %0, pmcr_el0" : "=r" (cc));
      result[0] = cc;
    I think its good so far but the actual problem is to use Hyp mode.
    I was using this small driver in Cortex-A15 (explaned here: http://bench.cr.yp.to/cpucycles/netwalker.html):
      #include <linux/module.h>
      #include <linux/kernel.h>
      MODULE_LICENSE("Dual BSD/GPL");
      #define DEVICE_NAME "enableccnt"
      static int enableccnt_init(void)
      printk(KERN_INFO DEVICE_NAME " starting\n");
      asm volatile("mcr p15, 0, %0, c9, c14, 0" :: "r"(1));    //  Write to HVBAR characteristic register.
      return 0;
      static void enableccnt_exit(void)
      asm volatile("mcr p15, 0, %0, c9, c14, 0" :: "r"(0));
      printk(KERN_INFO DEVICE_NAME " stopping\n");
      module_init(enableccnt_init);
      module_exit(enableccnt_exit);
    So, from the technical referece manual of cortex-a53, I got VBAR_EL2 characteristics register equivalent to HVBAR in aarch32. I modified the driver as
      asm volatile("MSR VBAR_EL2, %0" :: "r"(1));    //  Write to VBAR_EL2 characteristic register.
      return 0;
      asm volatile("MSR VBAR_EL2, %0" :: "r"(0));
    When I am inserting this into kernel. Its giving "segmentation fault". attached is the picture of dmeg command .
    I am not sure that whether I should set some vlaues to "Hyp Debug Control Register"?
    And
    I am getting whether I should use isb instructions as it was working as it is in cortex-a15?
    I appreciate any help.
