How to remap the vector table in an A9 core
I'm having an issue/misunderstanding on remapping the vector table for an A9 core in a bare metal (flat mapped) application. I assumed I could create a vector table in some arbitrary location in RAM, load that location into the vbar register:
ldr r0, =vector_tbl
mcr p15, 0, r0, c12, c0, 0 //write VBAR register
and when an interrupt occurred (via the gic/IRQ), control would pass to the IRQ handler. This isn't happening. Control actually passes to the svc handler with the cpu in IRQ mode. I'm pretty sure this is a result of not remapping the vector table correctly. Any guidance on this?
  • Hi there, I have moved your question to the Architectures and Processors forum. Many thanks!
  • Check the value of vector_tbl and the alignment.
  • The address of the vector table I'm trying to use is shown in the attached listing, line 289 which is at location 0x009005B0 (OCRAM). The exceptions are in the correct order. As the listing shows, 0x009005B0 is loaded into the VTOR register via function set_vbar (line 201). The problem I have is that when the interrupt occurs from the local timer (as mentioned above), execution jumps to line 230 instead of line 270. Interestingly, the mode is switched to IRQ mode. I put a breakpoint at line 230 to see if the vector table somehow got corrupted - it did not. I can set the next instruction to line 296 and it executes the "jump" to line 270 showing that the table is fine. Are there some other rules to setting the VTOR register that I'm overlooking?
      194
      195                              ASM_PUBLIC_BEGIN(_set_vbar)
      196                              ASM_PUBLIC_FUNC(_set_vbar)
      197
      198                           /************************************************************************
      199                            * Set the location of the hardware vector table into the VBAR reg
      200                            ***********************************************************************/
      201                           set_vbar
      202    000000EC 44009FE5           ldr r0, =vector_tbl
      203    000000F0 100F0CEE           mcr p15, 0, r0, c12, c0, 0      //write VBAR register
      204
      205                                // SCTLR bit V - location of exception vectors
      206    000000F4 100F11EE           mrc p15, 0, r0, c1, c0, 0       //read SCTLR
      207    000000F8 800DC0E3           bic r0, r0, #0x2000             //clear V bit
      208    000000FC 100F01EE           mcr p15, 0, r0, c1, c0, 0       //write SCTLR
      209
      210    00000100 1EFF2FE1           bx lr                           //return
      211
      212                              ASM_PUBLIC_END(_set_vbar)
      213
      214
      215
      216                                ASM_PUBLIC_BEGIN(undef_isr)
      217                                ASM_PUBLIC_FUNC(undef_isr)
      218
      219                           undef_isr
      220    00000104 FEFFFFEA           b      .
      221
      222                                ASM_PUBLIC_END(undef_isr)
      223
      224
      225
      226                                ASM_PUBLIC_BEGIN(svc_isr)
      227                                ASM_PUBLIC_FUNC(svc_isr)
      228
      229                           svc_isr
      230    00000108 FEFFFFEA           b      .
      231
      232                                ASM_PUBLIC_END(svc_isr)
      233
      234
      235
      236                                ASM_PUBLIC_BEGIN(prefetch_isr)
      237                                ASM_PUBLIC_FUNC(prefetch_isr)
      238
      239                           prefetch_isr
      240    0000010C FEFFFFEA           b      .
      241
      242                                ASM_PUBLIC_END(prefetch_isr)
      243
      244
      245
      246                                ASM_PUBLIC_BEGIN(abort_isr)
      247                                ASM_PUBLIC_FUNC(abort_isr)
      248
      249                           abort_isr
      250    00000110 FEFFFFEA           b      .
      251                                ASM_PUBLIC_END(abort_isr)
      252
      253
      254
      255                                ASM_PUBLIC_BEGIN(fiq_isr)
      256                                ASM_PUBLIC_FUNC(fiq_isr)
      257
      258                           fiq_isr
      259    00000114 FEFFFFEA           b      .
      260
      261                                ASM_PUBLIC_END(fiq_isr)
      262
      263
      264
      265                                ASM_PUBLIC_BEGIN(irq_isr)
      266                                ASM_PUBLIC_FUNC(irq_isr)
      267
      268                           irq_isr
      269                                // Save registers
      270    00000118 FF5F2DE9           push   {r0-r12, lr}
      271
      272                                // Call the IRQ Exception handler
      273    0000011C 18009FE5           ldr    r0, =irq_hnlr   //make sure bit0 is
                                                 0
      274    00000120 30FF2FE1           blx    r0
      275
      276                                // Return to normal program flow
      277    00000124 FF5FBDE8           pop    {r0-r12, lr}
      278    00000128 04F05EE2           subs   pc, lr, #4
      279
      280                                ASM_PUBLIC_END(irq_isr)
      281
      282
      283
      284
      285                              ASM_CODE_SECTION(vector_ram)
      286
      287                           // This is the actual hardware exception table, the address of which is loaded
      288                           // into the VBAR. This section must be aligned on a 4-byte boundary (VBAR)
      289                           vector_tbl
      290    00000000 18F09FE5           ldr pc, =__boot
      291    00000004 18F09FE5           ldr pc, =undef_isr
      292    00000008 18F09FE5           ldr pc, =svc_isr
      293    0000000C 18F09FE5           ldr pc, =prefetch_isr
      294    00000010 18F09FE5           ldr pc, =abort_isr
      295    00000014 00F020E3           nop                     // reserved
      296    00000018 14F09FE5           ldr pc, =irq_isr
      297    0000001C 14F09FE5           ldr pc, =fiq_isr
      298
  • Vbar must be aligned on 32byte boundary!
  • I saw some illusions to that, but could never find where it was documented. Thanks for the help. That solved the problem.
  • ARMv7AR Manual:
    B4.1.156   VBAR, Vector Base Address Register, Security Extensions
    Vector_Base_Address, bits[31:5]
    Bits[31:5] of the base address of the low exception vectors. Bits[4:0] of an exception vector is the
    exception offset, see Table B1-3 on page B1-1166.
    Bits[4:0]  Reserved, UNK/SBZP.
