Dear Arm community,
is there any real-time application to demonstrate the R5-lock step feature.
other than Error injection in to the test register ?
Thanks,
Ravinder Are
Hello Neil, would you know where we can find more information for Ravinder on the ARM Cortex-R5 lock step feature?
Hello Ravinder,
I am the product manager for the Cortex-R5.
Are you asking how to test the lock-step functionality of the R5 - how to create an error to check correct behavior?
Neil.
Hi Neil,
Thanks for your reply.I am looking for a real time application that can some how create an error to check the Lock-step behavior.
(Other than error injection testing logic )
Hi Ravinder,
The Cortex-R5 design provides two external input signals that may be available on your particular Cortex-R5 device:
DCCMINP*[0] Enable comparison error reporting
DCCMINP*[7] Inject an error for testing purposes
DCCMINP*[7] allows error injection to comparators, so this could be another way of testing system reaction to lock-step errors - but I assume this is what you mean by error injection testing logic.
There are other potential options but it will depend on the silicon design. Are you using a Cortex-R5 device from a specific supplier? The reason I ask is that the lock-step comparator logic is often modified by the ARM partner during their silicon design. They may enable other methods of fault injection for testing lock-step. The partner may also modify the debug system for their particular requirements.
One mechanism I can think of is through enabling debug. Debug logic is not replicated for the two cores, so any activity / modification to state via debug functionality to one core will lead to a comparator error. However, in the ARM deliverables example logic is provided that flags an error if invasive debug is attempted while the comparators are enabled. Therefore enabling debug might generate a comparator error through different route.
Placing the Cortex-R5 device near a strong source of radiation will also likely cause errors as bits may be flipped - but this not really a practical solution
If you are using a Cortex-R5 processor from a specific vendor it would be worth asking them if there are ways of easily testing the lock-step operation in their specific design.
Best regards,
Thanks Neil, It is helpful.
