Which ARM processor is HSA compatible?
I am new to the ARM community. I am currently studying the HSA (Heterogeneous System Architecture). ARM is member of this foundation.
I wonder which processor from ARM is HSA enabled? And on which devkit (raspberry, ODROID, or other) So I can use it for my tests.
  • Hello,
    would you like to know a pair of processors which can form HSA?
    If it is correct, the big LITTLE pair would be the solution. For example, Cortex-A17 and Cortex-A7 or Cortex-A72 and Cortex-A53.
    If the processor which can be MPCore (e.g. Cortex-A9, A7, A5, A17 and etc.), it has both SMP and AMP modes. In the AMP mode, HSA configuration would be possible.
    I hope this will help you.
    Best regards,
    Yasuhiko Koumoto.
