Cortex-A53 : complex array problem
Hello ;
I am working on Arm Cortex-A53 and here is the problem;
when ı am trying to allocate
  A= new comp[N]; >>
typedef std::complex< double > comp;>>
#include <complex>
struct complex<double>
typedef double value_type;
typedef __complex__ double _ComplexT;
_GLIBCXX_CONSTEXPR complex(_ComplexT __z) : _M_value(__z) { }
_GLIBCXX_CONSTEXPR complex(double __r = 0.0, double __i = 0.0)
#if __cplusplus >= 201103L
: _M_value{ __r, __i } { }
#else
__real__ _M_value = __r;
__imag__ _M_value = __i;
#endif
xsct% Info: Cortex-A53 #0 (target 9) Running
xsct% Info: Cortex-A53 #0 (target 9) Stopped at 0x4a028 (Hardware Breakpoint)    (the red spot jumps return that info at XSCT console)
my code just give a HTL instraction failed in that red spot. Same code was working on cortexa9
So could you help me ?
