In here : https://chromium.googlesource.com/external/github.com/ARM-software/arm-trusted-firmware/+/v0.4-rc1/docs/firmware-design.md#bl1-architectural-initialization
The arm-tf B1 code sets the LED and SYS_LED[7:3] shows the exception class.
Some of them I show here.
0x0 : Synchronous exception from Current EL with SP_EL0 0x1 : IRQ exception from Current EL with SP_EL0 0x2 : FIQ exception from Current EL with SP_EL0 0x3 : System Error exception from Current EL with SP_EL0 0x4 : Synchronous exception from Current EL with SP_ELxI can't understand what "Synchronous exception from Current EL with SP_EL0" mean here. If a core is in ELx, isn't it using the SP_ELx?When an exception is taken from a state, can the core have been in EL2 and and have been using SP_EL0 or SP_EL3?p.s I don't know how to format the text style in this question window. (I wish there be format copy- format paste key here like in MS windows)
You can choose (check TRM) if EL1/2/3 uses the respective SPs or EL0_SP. This is useful if you do not need a dedicated EL1_SP.
