Cortex A-35 prevent fetch code allocation in cache
I'm currently working on the i.MX8QX which contains a cluster of 4 A-35 cores. From my understanding, it is possible to prevent data cache allocation using the write or read allocate. From:
https://developer.arm.com/documentation/den0024/a/caches/cache-policies
The cache policies enable us to describe when a line should be allocated to the data cache and what should happen when a store instruction is executed that hits in the data cache.
The cache allocation policies are:
Write allocation (WA)
A cache line is allocated on a write miss. This means that executing a store instruction on the processor might cause a burst read to occur. There is a linefill to obtain the data for the cache line, before the write is performed. The cache contains the whole line, which is its smallest loadable unit, even if you are only writing to a single byte within the line.
Read allocation (RA)
A cache line is allocated on a read miss
Is there a similar parameter to prevent allocation in the instruction cache from fetch code ?
Kind Regards,
David
  • No. What would be the benefit of just reading one instruction from main memory?
  • Hi,
    The idea would be to lock the L2 data cache to prevent interferences on other cores or subsequent processes, and for the instructions, either also lock the L1 & L2 caches or only lock the L2 and let the L1 fetch and allocate code. The process would also least benefit from the current data/instruction contents in L2 cache. The idea is to not alter L2 and hence not impact execution time of other cores and other processes of current core.
    Étienne
  • IIRC, L2 is unified. You can try cash coloring. But I am not sure if it works for i-cache as well.
  • Hello David,
    From my understanding you want to prevent instruction to being allocated and stored in both L1 and L2 caches.
    That can be done at the MMU page level, by configuring the attributes of the page where your code is stored in DDR as inner non-cacheable and/or outer non-cacheable. Inner cacheability is for L1 instruction cache, and outer cacheability is for L2 cache.
    You may want to force the section of your code to be section (1MB) or page (4KB) aligned in your linker script.
    If you are worried about only specific piece of code, make sure to isolate it in a specific text section within your linker script. So that only this text section will be non-cacheable.
    Regards,
    Florian
