We made a M4F SoC with ETM function. ETM is the original setting of ARM.
But I can't use this function with ULinkPro and MDK.
Is there something I missed?
The ETM port as below:
GPIO0.26 = TRACESWO GPIO0.27 = TRACECLK GPIO0.28 = TRACEDATA[0] GPIO0.29 = TRACEDATA[1] GPIO0.30 = TRACEDATA[2] GPIO0.31 = TRACEDATA[3]
And I use Trace.ini to enable these pin when start debug sessnon:
/*------------------------------------------------------------------- ** Define the function to enable the trace port **-----------------------------------------------------------------*/ FUNC void EnableTPIU(void) { _WDWORD(0x40010008, 0xFC000000); // disable pull-up resistor for GPIO0.26~GPIO0.31 _WDWORD(0x40010010, 0xFC000000); // enable output enable for GPIO0.26~GPIO0.31 _WDWORD(0x40010018, 0xFC000000); // enable ALT function for GPIO0.26~GPIO0.31 } /*------------------------------------------------------------------- ** Invoke the function at debugger startup **-----------------------------------------------------------------*/ EnableTPIU(); /*------------------------------------------------------------------- ** Execute upon software RESET **-----------------------------------------------------------------*/ FUNC void OnResetExec(void) { EnableTPIU(); }
The debug setting, I choice the ULINK Pro
This is the Trace setting:
MDK start debug session:
MCU running
MCU halted by break-point. NO Trace Data.
Thanks your answer.
Ruemann
What is Keil-support saying?
