Hello
I'm working on the Bootloader stage (EL2), I'm trying to enable Interrupts with gic v3 in that stage
I've enabled routing IRQ, FIQ and Aborts from EL0, EL1 and EL2 to EL2 using these piece of code
MRS X0, HCR_EL2 AND X0, X0, 0xFFFFFFFFF7FFFFFF ORR X0, X0, 0x0000000000000038 MSR HCR_EL2, X0
when it comes to the interrupt activation, priority drop and deactivation the in IHI0069F it says in chapter 4.1.1 Activation
Activation
"The interrupt handler reads ICC_IAR0_EL1 for Group 0 interrupts, and ICC_IAR1_EL1 for Group 1 interrupts, inthe corresponding CPU interface to acknowledge the interrupt"
Priority Drop
"After an interrupt has been acknowledged, a valid write to ICC_EOIR0_EL1 for Group 0 interrupts, or a valid writeto ICC_EOIR1_EL1 for Group 1 interrupts, results in a priority drop."
so the question is there a relative registers to do the same function at EL2 ?
Or is there a whole different configuration when working in EL2 for the GIC and the CPU_Inteface?
I do not think EL2 is meant to handle interrupt itself. It will direct them to the respective "guest"
