I am trying to run the testbenches provided in the design start for University and Research for ARM M3. I am not getting any errors neither warnings in the simulation (I am using Modelsim); however, I am not getting the TEST PASSED statement. So, what might be the cause for that?
I am using Modelsim 10.5b
Motasem Sakr said:what might be the cause for that?
The test is failing ?
I do not know that. I am running the provided testbenches and source code from ARM. So, it should pass I assume.
Presumably you've made some error/omission.
Surely, there must be more detail available somewhere that tells you why it failed ?
Your teacher / supervisor / tutor would be best placed to help you ...
