Dear all,
Consider a scenario where a bare minimum hardware-assisted hypervisor is hosting 2 simple guest OSes on a dual-core Cortex-A15. I want to accurately measure the time it takes to switch from the guest OS to the hypervisor and then from the hypervisor to the other guest OS. Could you please advise me on a reliable and robust way to measure accurately the aforedescribed world switch time. Please share your experience.
Many thanks.
The same way you'd measure the time of anything else ...
The main issue you will have is making sure that both guests and the hypervisor can "see" the counters and the peripheral, so may be a little bit of platform setup needed.
HTH, Pete
You could use the generic timer (ARM Cortex-A15 MPCore Processor Technical Reference Manual: Chapter 9. Generic Timer).
Something else to consider is what you class as the switch having finished. For example, the Hypervisor might use "lazy" context switching for the VFP registers. Does that still count as finished?
