Dear experts,
working for Cortex-A55MP, EL1 in Aarch32, svc mode:
Both 2 level of table entry are attributed as (inner WB/WA, and outer WB/WA) and the MMU is set TTBR0 as (N=0, Inner WB WA , and Outer WB WA), is this not enough to have MMU to observe the page table entry change made by the same CPU core ?
If we add a DCCMVAC after modification of page entry, it works. Why ?
If a core is configured to work isolatedly, without shareability of these memory space to other cores.And if it indeed have to flush data cache of modified page table entry, why it still have to take DCCMVAC, instead of DCCMVAU ?( Sure, it always fails for DCCMVAU applied after table entry modification.)
MMU access the same private/common cache layer with it CPU core, doesn't it ?
From A-R-M of ARMv8-Cortex-A (DDI 0487D.a), the G.5.9 TLB maintenance requirements, we do not see any hint about the necessary to flush data cache of table entry.
The only one example for a uniprocessor system in G.5.9.1, there is no data cache flush operation.
Therefore, in a uniprocessor system, an example instruction sequence for writing a translation table entry, covering changes to the instruction or data mappings is: STR rx, [Translation table entry] ; write new entry to the translation table DSB ; ensures visibility of the new entry Invalidate TLB entry by VA (and ASID if non-global) [page address] Invalidate BTC DSB ; ensure completion of the Invalidate TLB instruction ISB ; ensure table changes visible to instruction fetch
For SMP system, It neither not find anything about necessary of data cache flush operation.
All above mentions, I wonder the definition of shareability domain of MMU and feel confused totally.
update:
1) Cortex-A55 only take " both Inner Write-Back Cacheable and Outer Write-Back Cacheable" as cached.2) MMU.IRGN[1..0] is composited from { bit0, bit6 } of TTBR0. I mis-spell the bit order and result as "Inner Write-through".
After I correct the MMU.IRGN setting, it works without flushing data cache of modified page entry.
