Can AXI data channel drop a burst?
       I have a question regarding the AXI protocol, which I can seem to find the answer from the spec.
       On the AXI read bus.
       If the master send the slave 10 read burst commands, does the slave must commit  to send 10 burst of the data back the master.
       Can the slave drop a burst? In this example can the slave send less then 10 burst of data. ?
Ton
  • Hello Ton,
    No.
    No.
    The slave must provide a response to every command.
    Xingguang
