Hi there,
I was using Codewarrior targeting Cortex-R4 CPU to build Firmware. When doing a division coprocessor was used and caused exception.
Here is the division in C:
u8 i, j = 8;
i = j / 3;
Disassembly:
(u8 i, j = 8;)
mov r5, #0x8
(i = j / 3;)
mov r1, #0x3
mov r0, r5
mrc p6, 1, r0, c0, c1, 4
and r4, r0, #0xff
When running mrc, exception occurred.
Does anybody have any idea why it happens? Anyway to disable coprocessor in this operation?
Thanks.
I don't know about the Cortex-R4 myself but
Divide and Conquer
indicates it supports divide in Thumb mode but not ARM mode
It is worth checking you actually are compiling for Cortex-R4 if it was supposed to be ARM mode code. You can disable div as a temporary fix by saying you're compiling that routine for a Cortex-A8 but I'd fix the root cause, temporary things seem to get a zombie life of their own.
I'd have thought there was a bug there somewhere as one should not be seeing an mrc so you should send in a bug report with a short bit of code to reproduce it. I tend to the bug first investigate afterwards crowd myself even if it may later turn out to be something silly.. Hopefully some ARM person will advise you better here about that.
Can you check what compiler flags you are using?
The "mrc p6, 1, r0, c0, c1, 4" is interesting, as it's an access to coprocessor 6. There isn't (AFAIK) a coprocessor 6 on the Cortex-R4, and accessing a non-existent coprocessor does cause an Undef exception.
If it's a custom coprocessor on that SoC it may need to be enabled, check with the silicon provider. Otherwise (and this seems more likely) you might be building for the wrong part - where the part you're building for had the coprocessor and this one doesn't.
Thanks to the helps from daith and Martin. It turns out the micro-kernel I'm using is built with hardware division enabled. That HW division instruction was carried to Cortex-R5 which supports SW division only. Everything turns ok after rebuilding the micro-kernel for Cortex-R5.
