When the following line is executed, what is the behavior with respect to the other words in the cache line?
STR r1, [r0]
The 4 bytes of data in r1 is written to the address in r0. But cache-lines are 32 bytes long. Assuming write-through (and ignoring store-buffers), are all 32 bytes written to backing memory?
I think that this is how the cache behaves, and this question seems to confirm it: https://community.arm.com/processors/f/discussions/1318/memory-acces-and-cache/4282#4282
I haven't found anything explicit in the ARM ARM about this, so a pointer to the right page there would also really be appreciated!
Thanks,
James
I think CWG in CTR (B4.1.42 CTR, Cache Type Register, VMSA) is a good hint.
CWG, bits[27:24] Cache Write-back Granule. The maximum size of memory that can be overwritten as a result of the eviction of a cache entry that has had a memory location in it modified, encoded as Log2 of the number of words. A value of 0b0000 indicates that the CTR does not provide Cache Write-back Granule information and either:• the architectural maximum of 512 words (2Kbytes) must be assumed• the Cache Write-back Granule can be determined from maximum cache line size encoded in the Cache Size ID Registers.Values greater than 0b1001 are reserved.
(Wrong:On Cortex-A9 CWG (cache write back) is 3 (=> 2^3 = 8), so (edit:not the whole cacheline, but 8 words (edit: was bytes) are written back.
Corrected: On Cortex-A9 CWG (cache write back) is 3 (=> 2^3 = 8), so the whole cacheline (8 words) are written back.
"encoded as Log2 of the number of words" <- For your example of 3, wouldn't that indicate 8 words, which would be the whole cacheline?Thanks, this is helpful. I guess my question now is: The CWG defines the maximum size of memory that is overwritten by a cache eviction; is that the same as the minimum size?
