ARMv8: strongly ordered memory and exclusive access
We are developing a bare metal secure OS on a NXP LS1043a board, with a Cortex A53 v8 core.
While debugging some issue with DMA, I decided to switch all kernel mapping from Normal cacheable to Strongly ordered (Device-nGnRnE memory type) and then witness a  IMPLEMENTATION DEFINED fault (Unsupported Exclusive or Atomic access) fault. This has been triggered by the following code:
typedef atomic_flag lock_t;
void lock_lock(lock_t *lock)
    while (atomic_flag_test_and_set_explicit(lock, memory_order_acquire)) {
    wfe();
It is compiled to the ldaxrb/stxrb instruction, which seem to trigger this fault on this CPU.
1) Can anyone explain to me why we need caches to be activated to use exclusive access instructions ?
2) Is it possible to get a "uncached" configuration which still support exclusive access, to help us debug our DMA situation ?
Best,
V.
  • Hi ,
    The ARMv8-A Reference Manual has a chapter corresponding to what you describe I think:
    "Exclusive access instructions and Shareable memory locations"
    It lists the memory types for which it is architecturally guaranteed that a global Exclusives monitor is implemented.
    I don't think device nGnRnE is in that list, which means an implementation is allowed to have a number of listed behaviours.
    One of the allowed behaviour is indeed to generates an IMPLEMENTATION DEFINED MMU fault.
    Best regards,
    Vincent.
  • Thank you for the feedback, I'll check this chapter right away
