Ethos U55 Driver Unit Test Integration
I have integrated the Ethos U55 driver unit tests for 128MAC configuration as provided under ethos-u-core-platform-24.11\ethos-u-core-platform-24.11\applications\driver_unit_tests
When I run the tests, I see that the IRQ tests are passing, whereas the conv test gets stuck. I have checked the NPU status and it seems to be busy/stuck. Below are the debug logs
              IRQ Test
I: Acquiring NPU driver handle
D: ethosu_reserve_driver(): NPU driver handle 0x300024d8 reserved
D: ETHOSU_PMU_Enable(): Enable PMU
I: Soft reset NPU
D: ethosu_dev_set_clock_and_power(): CMD=0x00000000
D: ETHOSU_PMU_CNTR_Enable(): mask=0x80000000
D: ETHOSU_PMU_Set_EVTYPER(): num=0, type=1, val=17
D: ETHOSU_PMU_CNTR_Enable(): mask=0x00000001
D: ETHOSU_PMU_Set_EVTYPER(): num=1, type=2, val=32
D: ETHOSU_PMU_CNTR_Enable(): mask=0x00000002
D: ETHOSU_PMU_Set_EVTYPER(): num=2, type=5, val=35
D: ETHOSU_PMU_CNTR_Enable(): mask=0x00000004
D: ETHOSU_PMU_Set_EVTYPER(): num=3, type=0, val=0
D: ETHOSU_PMU_CNTR_Enable(): mask=0x00000008
D: ETHOSU_PMU_CYCCNT_Reset(): Reset PMU cycle counter
D: ETHOSU_PMU_EVCNTR_ALL_Reset(): Reset all events
D: ethosu_invoke_async(): NOP
D: ethosu_invoke_async(): COMMAND_STREAM
I: handle_command_stream: cmd_stream=0x33e80790, cms_length 1
D: ethosu_dev_run_command_stream(): QBASE=0x0000000033e80790, QSIZE=4, cmd_stream_ptr=0x33e80790
D: ethosu_dev_run_command_stream(): BASEP0=0x0000000000000000
D: ethosu_dev_run_command_stream(): BASEP1=0x0000000000000000
D: ethosu_dev_run_command_stream(): BASEP2=0x0000000000000000
D: ethosu_dev_run_command_stream(): BASEP3=0x0000000000000000
D: ethosu_dev_run_command_stream(): BASEP4=0x0000000000000000
D: ethosu_dev_run_command_stream(): BASEP5=0x0000000000000000
D: ethosu_dev_run_command_stream(): BASEP6=0x0000000000000000
D: ethosu_dev_run_command_stream(): BASEP7=0x0000000000000000
D: ethosu_irq_handler(): Got interrupt from Ethos-U
D: ethosu_dev_run_command_stream(): CMD=0x00000001
D: ethosu_wait(): Inference finished successfully...
D: ETHOSU_PMU_Get_CCNTR(): val=17455486
D: ETHOSU_PMU_Get_CCNTR(): val=18184607
D: ETHOSU_PMU_Get_EVCNTR(): num=0, val=17993647
D: ETHOSU_PMU_Get_EVCNTR(): num=1, val=18861612
D: ETHOSU_PMU_Get_EVCNTR(): num=2, val=18
D: ETHOSU_PMU_Get_EVCNTR(): num=3, val=0
PMU={cycleCount=18184607, events=[17993647, 18861612, 18, 0]}
D: ethosu_release_driver(): NPU driver handle 0x300024d8 released
/home/tk/platform/services/ethosu_tests/src/ethosu_unity_test.cc:40:run_ethosu_irq_test:PASS
              Conv Test
Running 100 iterations using sync API...
I: handle_command_stream: cmd_stream=0x33e80630, cms_length 84
D: ethosu_dev_run_command_stream(): QBASE=0x0000000033e80630, QSIZE=336, cmd_stream_ptr=0x33e80630
D: ethosu_dev_run_command_stream(): BASEP0=0x0000000033e805a0
D: ethosu_dev_run_command_stream(): BASEP1=0x0000000033e800d0
I figured out that the problem lies with the NPU_OP_DMA_START command. It could mean that the DMA configuration commands executed prior to this are incorrect, specifically
NPU_SET_DMA0_SRC could be pointing to an incorrect region.
Should I need to modify this default address of 0x00000030 and point it to the exact memory location of tensorflow
(tflmArena) or should it point to the tflmModel?
Below is the reference command stream given by ARM.
    DRIVER_ACTION_MAGIC()
    DRIVER_ACTION_NOP()
    DRIVER_ACTION_NOP()
    DRIVER_ACTION_COMMAND_STREAM(84)
    0x30, 0x01, 0x00, 0x00,                          // cmd0.NPU_SET_DMA0_SRC_REGION          0   -
    0x30, 0x40, 0x00, 0x00, 0x30, 0x00, 0x00, 0x00,  // cmd1.NPU_SET_DMA0_SRC                 0   0x00000030 (48) 0x33ebb1f0
    0x31, 0x01, 0x01, 0x00,                          // cmd0.NPU_SET_DMA0_DST_REGION          1   -
    0x31, 0x40, 0x00, 0x00, 0x80, 0x04, 0x00, 0x00,  // cmd1.NPU_SET_DMA0_DST                 0   0x00000480 (1152)
    0x32, 0x40, 0x00, 0x00, 0x50, 0x00, 0x00, 0x00,  // cmd1.NPU_SET_DMA0_LEN                 0   0x00000050 (80)
    0x10, 0x00, 0x00, 0x00,                          // cmd0.NPU_OP_DMA_START                 0   -
Thanks for the insights!
