Is there a flag to print logs for KleidiAI when integrated with third-party AI/DL/ML frameworks?
I’m currently using KleidiAI in conjunction with PyTorch/TorchAO/Torchchat. I’m trying to figure out how to enable logging for the operations or processes running within KleidiAI when used alongside the other framework. Is there a flag, environment variable, or configuration option that can be set to print detailed logs for debugging or monitoring purposes? Could someone help with this or point me in the right direction?
  • There isn't logging in KleidiAI currently. The debugging is largely through asserts. Is there something you'd particularly like in the logging? I can mention it to the Kleidi team.
    I'm also very interested in what your KleidiAI/PyTorch based project is!
