Is it possible to rebuild a tensorflow lite model with cmsis-nn to run on a MCU with a Cortex-M?
We have followed the guide posted on arm:s website for converting neural networks for ARM Cortex-M using CMSIS-NN although it is not for the tflite model we found that it gave a good example for how to start. We then found the s8 layers made specifically for the Tensorflow Lite model (for examplearm_depthwise_conv_s8). However, the documentation is rather poor and we are having troubles understanding all the parameters for the layer function calls.
Is there any more documentation available for these parameters than in the arm_nnfunctions.h file?
Are there any existing examples for using cmsis-nn with a tflite model?
We are currently using the layers arm_depthwise_conv_s8, arm_convolve_s8, arm_max_pool_s8_opt, arm_relu_q7 and arm_fully_connected_s8.
Could someone please explain the parameters listed in the code blocks bellow for us?
* @brief S8 basic fully-connected and matrix multiplication layer function for TF Lite [...] * @param[in] nb_batches number of batches * @param[in] input_offset tensor offset for input. Range: -127 to 128 * @param[in] filter_offset tensor offset for filter. Range: -127 to 128 * @param[in] out_mult requantization parameter * @param[in] out_shift requantization parameter * @param[in] output_offset tensor offset for output. Range: int8 [...] * @param[in] output_activation_min for clamping * @param[in] output_activation_max for clamping arm_status arm_fully_connected_s8(...);
* @brief Basic s8 convolution function [...] * @param[in] output_shift pointer to per output channel requantization shift parameter. * @param[in] output_mult pointer to per output channel requantization multiplier parameter. * @param[in] out_offset output tensor offset. Range: int8 * @param[in] input_offset input tensor offset. Range: int8 * @param[in] output_activation_min Minimum value to clamp the output to. Range: int8 * @param[in] output_activation_max Minimum value to clamp the output to. Range: int8 arm_status arm_convolve_s8(...);
* @brief Basic s8 depthwise convolution function [...] * @param[in] output_shift pointer to per output channel requantization shift parameter. * @param[in] output_mult pointer to per output channel requantization multiplier parameter. [...] * @param[in] output_offset offset to elements of output tensor * @param[in] input_offset offset to elements of input tensor * @param[in] output_activation_min Minimum value to clamp the output to. Range: int8 * @param[in] output_activation_max Minimum value to clamp the output to. Range: int8 [...] arm_status arm_depthwise_conv_s8_opt();
Thank you!
Hey! Sorry for the delay.
If you look at the repo for TF, there are Tensorflow Lite for Microcontroller examples.
https://www.tensorflow.org/lite/microcontrollers
CMSIS-NN is pushed into TFLite Micro
Start there and let me know if that helps,
As Karl has pointed to below there are a few examples included with pointers in the getting started with microcontrollers guide
https://www.tensorflow.org/lite/microcontrollers/get_started
https://github.com/tensorflow/tensorflow/tree/master/tensorflow/lite/micro/examples/
To build the examples with CMSIS-NN optimized kernels instead of reference kernel add TAGS=cmsis-nn to the make line in the examples
https://github.com/tensorflow/tensorflow/blob/master/tensorflow/lite/micro/kernels/cmsis-nn/README.md
Let us know if that helps
Thanks for the update and quick reply. I'll be sure to keep an eye on this thread.
