I am seeking assistance on the Arm forum to understand how the 1-bit ACTIVE signal in the Arm® Power Policy Unit Architecture Specification corresponds to different power modes, as mentioned in section 3.3.2 Q-Channel PPU Power Modes Transitions. This section discusses various transitions between power modes, but given that the ACTIVE terminal of the Q-channel interface is a 1-bit signal, how does it map to different power modes?
Any insights or explanations on this matter would be greatly appreciated. Thank you.
Hi there, thanks for asking a question. Please take a look at our list of forums here and let me know where is best to move your question to. Thanks.Forums
“SoC Design and Simulation forum”
Thanks.
This is described below Figure 3-2 in the Power Policy Unit Architecture Specification
"Although multiple power modes are supported with a Q-Channel PPU it only transitions between ON and the power mode programmed in the PPU_PWPR register"
If QACTIVE is asserted, that indicates the device needs to be in the ON state. If it is deasserted, then moving to the Q_STOPPED state will mean it takes the power value programmed in the PPU_PWPR register
