AHB Slave HREADY
Hello
I am new to AMBA and I am writing code AHB slave in one of my project, I have read specs.
My question is Is there any specific condition for slave when it gives HREADY low?
I am confused with HREADY signal that it is provided by the slave but at which time and in which condition HREADY becomes low?
Thanks in advance.
  • Hi ajoo,
    HREADY is used by a slave to add wait states to the data phase of an access, so whenever it needs more time to complete a transfer request. The reasons why that slave might need to add a wait state depend on the slave design.
    For example if the slave is a bridge to an APB slave, the APB access takes a minimum of 2 cycles to complete, so at the end of 2 cycles the AHB slave "bridge" can then drive HREADY high to signal the APB access has completed, but it needed to hold HREADY low for the 2 cycles during which the APB access was occuring (it needed to stall the master).
    Hope that helps,
    JD
