I'm workign in a SoC integration of a Cortex-M0 core. I've done my research but I can't seem to find an answer to an, in theory, easy question. Appreciate if someone can point me on the right direction.
We have prototyped the Cortex M0 system MCU into an FPGA using the system design kit. The ROM is modelled in the FPGA as a RAM block, and it can be reprogrammed when in debug mode via the SWD debugger. The program memory can also be "hard" programmed via synthesys.
However, and here is the question, I fail to understand how the "flash download" works. Maybe I am misunderstanding something system-level, but I would think that the SWD debugger should be able to, out of debug mode, to just program the flash, and let the processor start runnign the program. This is what I understand as flash download. In final silicon this would require of some sort of flash algorithm to write to flash, but I would expect this not necessary on FPGA as it is just modelled as a number of registers.
I've had a look at a lot of documents (ARM Debug Interface v5 Architecture Specification (ARM IHI 0031), ARM CoreSight Architecture Specification (ARM IHI 0029)), but they never mention anything related to flash download
What I am missing here?
View all questions in SoC Design forum
