problem with sim800
hi, I wrote a code for an SMS controlled irrigation system. it has three modes: manual mode which can turn a Solenoid valve on and off with an SMS, semi-auto which can turn a solenoid valve on for a specific duration and turn it off using an SMS. and automatic mode which can for example turn a solenoid valve on for an hour every day at a specific time for instance 5 am. I have no problem with the first two modes. but I encountered a problem with the third mode. I need to use a gsm clock for this mode and I wrote a function for testing that extracts the time after we send a message to sim800 and texts back the time. I want to use this time to compare it to 5. when I use this function in my code nothing works and I can't turn the LED on with SMS. when I delete this function the code works fine. what is the problem here?
my compiler is Keil and I use stm32f103ret6.and the function that I have a problem with it is send_clock.
0
