EXC_RETURN when is floating point stack save?
On the M4F when does the EXC_RETURN  bit[4] get cleared to indicate the floating point stack is saved?
Specifically does the core push the floating point stack (S0-S15) on the stack anytime the floating point hardware is enabled or does it do it only when a floating point operation is in process and the exception occurs?
Trampas
0
