Site
Search
User
Site
Search
User
Groups
Arm Research
DesignStart
Education Hub
Graphics and Gaming
High Performance Computing
Innovation
Multimedia
Open Source Software and Platforms
Physical
Processors
Security
System
Software Tools
TrustZone for Armv8-M
中文社区
Blog
Artificial Intelligence
Automotive
Healthcare
HPC
Infrastructure
Innovation
Internet of Things
Machine Learning
Mobile
Smart Homes
Wearables
Forums
All developer forums
IP Product forums
Tool & Software forums
Pelion IoT Platform
Activity
Support
Open a support case
Documentation
Downloads
Training
Arm Approved program
Arm Design Reviews
More
Cancel
Developer Community
IP Products
Processors
Jump...
Cancel
Processors
Cortex-A / A-Profile forum
L2 cache error injection for instructions and Prefetch Abort
Blogs
Forums
Videos & Files
Help
Jump...
Cancel
New
State
Not Answered
Replies
Subscribers
275 subscribers
Views
Users
0 members are here
Related
Offline
flongnos
1 month ago
I am using an ARM dual core Cortex A9 CPU as part of our satellite computer SoC, and I am trying to inject errors in the different cache levels of the CPU.
In particular I am trying to trigger a Prefetch Abort by corrupting instructions stored in the L2 cache, which is shared between the instructions and the data.
For this purpose I implemented the following sequence:
1) Configured all MMU pages as non-cacheable by default in the MMU translation table
2) Disabled caching of page table within inner and outer caches
3) Mapped a function to a known memory region (w/ a dedicated section in the linker script, with fixed address and size)
4) Configured the MMU page corresponding to this region as inner non-cacheable, outer non-cacheable
5) Then I perform the following error injection sequence:
a) Enable the L2 cache parity checking
a) Execute the function, so that it loads the instruction into L2 cache
b) Disable
c) Write all the cachelines of the function's memory region with a fixed pattern e.g. 0x5a5a5a5a
d) Enable
c) Execute again the function
--> In my understanding, this should normally trigger a parity error and thus a Prefetch Abort... but that is not the case in my test
I suspected that the Point of Unification between instructions and data was incorrectly set. As a recall, "the Point of Unification stands for the point at which the instruction and data caches and translation table walks of the core are guaranteed to see the same copy of a memory location. For example, a unified level 2 cache would be the point of unification in a system with Harvard level 1 caches and a TLB for caching translation table entries." Source:
https://developer.arm.com/docs/den0024/latest/caches/point-of-coherency-and-unification
<br>
There are no register to define the cache level associated with the Point of Unification Uniprocessor between instructions and data.
However
there are registers to define the Level of Unification Uniprocessor, which defines "the last level of cache that must be cleaned or invalidated when cleaning or invalidating to the point of unification for the Inner Shareable shareability domain."
Source:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.100236_0002_00_en/zsu1423532383435.html
<br>
So I checked that the Level of Unification for the ARM Cortex A9 in our SoC through reading the Cache Level ID Register. It appears that:
- Level of Unification Uniprocessor (LoUU): 3b'001
- Level of Coherence (LoC): 3b'001
- Level of Unification Inner Shareable (LoUIS): 3b'000
The maintenance broadcast bit of the ID_MMFR3 register is set as 3b'010 which stands for cache maintenance operation behavior is only related to their own definition. For example invalidate L1 instruction cache to Point of Unification will indeed invalidate instructions up to the PoU. <br>
In otherwords, since the LoUU is L1 cache it means that the PoU is the L2 cache. As a result I should be able to corrupt the instructions in L2 cache. <br>
So my question is: why
modifying the instruction stored in L2 cache with a store issued in the data pipeline (without flushing it DDR for synchronization with the instruction pipeline) does not corrupt it and trigger an abort?
<br>
Regards,
Florian
By title
By date
By reply count
By view count
By most asked
By votes
By quality
Descending
Ascending
All recent questions
Unread questions
Questions you've participated in
Questions you've asked
Unanswered questions
Answered questions
Questions with suggested answers
Questions with no replies
Not Answered
Priority Drop and Deactivation Interrupts at EL2
0
Cortex-A35
GICv3/v4
Armv8-A
CoreLink GIC-500
537
views
1
reply
Latest
2 days ago
by
42Bastian Schick
Not Answered
Does ARMv8-A has VC_CORERESET or something similar?
0
Cortex-A53
475
views
0
replies
Started
4 days ago
by
Ranjith TC
Not Answered
performance of floating point
0
Cortex-A53
AArch64
Floating-Point Execution
601
views
1
reply
Latest
4 days ago
by
42Bastian Schick
Answered
How to start ARM Programming???
0
Raspberry Pi
Cortex-A
Cortex-A8
Cortex-M
84133
views
6
replies
Latest
7 days ago
by
Sam Jewel
Answered
Differences between Armv7 to Armv8?
0
75851
views
7
replies
Latest
8 days ago
by
42Bastian Schick
