Arm Cortex-A8 program flow prediction
I am examining ARM-Cortex A8 flow prediction abilities, in order to done this i implemented below code:
in above code, i will execute if statement with true condition 8-time for training branch predictor of CPU, and in 9th i expect that cpu access to SecretDispatcher[9 * 512] speculatively however the condition is not true. this is just simple spectre-v1 PoC attack and i implemented this attack successfully on intel X86 processor with same logic and i expect that this work also in Cortex-A8 as arm clarified that this processor is vulnerable against this attack.
there is anything that i missing?? there is anything that i should do to enable program flow prediction on ARM-Cortex A8??
0
