Hi All,
I am working in Arm Cortex M4. I needs to rotate the display to 90 deg. Will you please provide the solution. I am using Display Processing Unit.
Thanks & Regards,
Vinoth S,
vinoth said:I am working in Arm Cortex M4
So why have you posted this in the Infrastructure Solutions forum?
vinoth said:the display
what display?
vinoth said:I am using Display Processing Unit
a what?
vinoth said:Will you please provide the solution
Surely, that is your job?
What have you tried?
Where are you stuck?
vinoth,
There are several things wrong with this post, I would advise you to take the following actions:
1) Please re-examine your post/question and exercise proper forum etiquette. It is near impossible for anyone to answer this question the way it is written. I would suggest a quick Google search on "Forum Etiquette" and some light reading to learn how to ask questions in a forum, this will provide viewers with the information needed to help. It will also improve your chances at getting an answer in a reasonable amount of time.
2) Based on the little amount of information, I would say this question does not belong in this category. Please explore the other categories on the forum list [1], possibly even the one labeled for Arm Cortex-M [2] topics.
I will be requesting this thread be removed if actions are not taken.
[1]: https://community.arm.com/developer/f[2]: https://community.arm.com/developer/ip-products/processors/f/cortex-m-forum
Cheers!
