I am trying to port Intel AVX intrinsics to a arm64 platform. My code contains _mm256_loadu_pd, _mm256_stream_pd, and __m256d types. Is there a existing solution available that maps these intrinsics to the aarch64 platform? Any help would much appreciated.
weegz said:
Hi weegz
There is the application notes for migrating-from-ia-32-to-arm, you can check from below link:
https://developer.arm.com/docs/dai0274/latest/migrating-from-ia-32-to-arm-application-note-274
Jett Zhou
