I am using Nuvoton M058LBN. In my code, my while 1 there are some functions which should run continuously. But it was getting reseted . So for checking I printed some statement which is getting printed 10 times after which it stops printing and restarts the controller.
So the possibilities I thought is it might be because of some interrupt but how can it be so periodic. Can anybody please help me with this? How can I check the cause of reset? I am not able to understand why it is getting reseted. Sorry if you find this question silly.
Thanks in advance.
Your MCU voltage may not be stable.
Perhaps your MCU power domain cannot drain enough current to run the MCU continuously.
Is the software watchdog getting served in time ? You may like to check the reset status register first to identify the source of reset. Usually most of the microcontrollers have such status register.
