Tools, Software and IDEs blog Open Source Toolchains - ARM Status Update
  • LLVM
  • open-source
  • GCC
Stefano Cadario
Stefano Cadario
April 18, 2015
3 minute read time.
ARM has always been committed to work with the ecosystem and cooperate with partners to get the best out of our cores. One important aspect of the cooperation is sharing what we have done in the open source and what we plan to do in the near future.
GNU Toolchain
In the first quarter of 2015 we focused on getting GCC 5 ready for release, plus some work on both A-Profile and R/M-Profile processors.
In particular, for Cortex-A processors, we made improvements to the instruction scheduling model, more accurate now, and we set an additional number of compiler tuning parameters which will lead to performance improvements on Cortex-A57. We also added support for the new Cortex-A72 and performed an initial tuning for performance.
On the Cortex-R/M class we created Thumb-I Prologue/Epilogues in RTL representation in order to allow the compiler to operate further tuning on functions call/return.
Additional work has been done, along with the community, for  improving NEON® intrinsics, refiningstring routines in glibc and implementing aeabi_memclr / aeabi_memset / aeabi_memmov in Newlib.
What’s next?
For the second quarter of 2015, we plan to complete what we started at the beginning of the year: first of all we are going to continue supporting and helping with the release of GCC 5. This is an important milestone and we want to make sure ARM support this. We will continue to work on adding support for ARMv8.1-A architecture in GCC and improving performance for Cortex-A53 and Cortex-A57. For example we noticed that GCC is generating branches to compile code with If/Then statements where a conditional select could be used instead: compiler engineers are exploring this optimisation opportunity which could potentially give a significant performance boost.
LLVM Update
The activity on LLVM has been focused on improving both AArch32 and AArch64 code generation: we added Cortex-A72 basic support and continue to advance the performance of the code generated for ARMv8 architecture such as improving unrolling heuristics.
Initially our efforts have been mainly directed to ARMv8 but we are now gradually making big advancements on ARMv7-A and ARMv7-M as well (read section MC-Hammer).
Supporting cores is not our only concern: the software ecosystem is important for us and in the last quarter we’ve been fixing stack re-alignment issues with the Android Open Source Project when built with LLVM.
What’s next?
During the next three months we will extend the support for ARMv8.1-A architecture and we will continue to work on performance optimisations. Some of the areas we will target are vectorisation, inlining, loop unrolling and floating point transformations. We are also discussing the support for strided accesses of the autovectorizer to maximise the usage of structure load and stores.
We will continue to support the Android Open Source Project (AOSP). In particular we will focus on stack size usage: LLVM is not performing as well as it could be in determining when local variables are not used anymore (“lifetime markers”) causing an unnecessary increase of stack usage.
MC-Hammer
Richard Barton presented MC-Hammer at Euro-LLVM 2012 (you can find presentation and slides here at LLVM website http://llvm.org/devmtg/2012-04-12/), a tool we’ve been using to verify the correctness of LLVM-MC against our proprietary reference implementation.
In 2012 we estimated that at the time ~10% of the all ARM instructions for Cortex-A8 were incorrectly encoded and 18% of instructions were incorrectly assembled when using LLVM. Over the past three years we gradually fixed corner case bugs and we are now confident that v7-A and v7-M variants of the ARM architecture are correct, as well as AArch64. This is a great result and it means that this functionality in LLVM-MC can be trusted and built upon.
We participated at EuroLLVM 2015 on 13th and 14th April in London (UK) and we will be at GNU Tools Cauldron 2015 on 7th/8th/9th August in Prague (Czech Republic): please come and talk with us! For more details please refer to the full presentation given by Matthew Gretton-Dann available on YouTube and his slides attached to this blog or get in contact with us if you need further information. We would like to hear from you on what you are doing in this space and maybe work together to achieve a shared goal.
20150330-sixmonth-update-1q15.pdf
  • Alban Rampon
    Alban Rampon over 10 years ago
    I stumbled upon a presentation made by Matthew Gretton-Dann for those who prefer a video format:
    Open Source Compiler Roadmap Update March 2015 - YouTube
    Diego Russo
    Diego Russo
    • October 9, 2025
  • Python on Arm: 2025 Update
    Diego Russo
    Diego Russo
    • August 21, 2025
    Stephen Theobald
    Stephen Theobald
    • July 18, 2025
