Servers and Cloud Computing blog Memcached performance benchmarking on AWS Graviton2 reveals over 50% price-performance gains
  • aws
  • Graviton2
  • Arm64
  • infrastructure
  • Neoverse
Pranay Bakre
Pranay Bakre
January 28, 2021
3 minute read time.
As highlighted at the AWS re:Invent 2020, many customers are reaping the price-performance benefits of using  the Arm Neoverse powered AWS Graviton2 processors. Amazon EC2 M6g, C6g, R6g, and C6gn instances provide up to 40% better price performance over x86-based Amazon EC2 instances.
In this blog, we showcase 51% performance benefits of running Memcached workloads on AWS Graviton2 based instances compared to equivalent x86-based instances. We are publishing a series of workload performance benchmarks on Graviton2 and recommend checking out our NGINX, Elasticsearch blogs.
Memcached is an open-source, high-performance, distributed memory object caching system and is a popular choice for powering real-time applications in web, mobile apps, gaming, ad-tech, and e-Commerce. It is an in-memory key-value store that offers higher application performance by removing the need to access disks or SSDs. By keeping its data in memory, it avoids delays and can access data much faster than traditional disk-based databases.
For performance benchmarking of Memcached we used memory-optimized Amazon EC2 R6g instances. These instances are ideal for running memory intensive workloads like Memcached. We installed Memcached open-source binaries on R6g and R5 instances and observed the following throughput and latency results:
 Figure 1: Performance gain for R6g vs R5 instances for self-hosted Memcached deployment
 Figure 2: Lower latency for R6g vs R5 instances for self-hosted Memcached deployment.
Performance benchmarking process and results
We deployed Memtier, an open-source high-throughput benchmarking tool for Memcached, on separate EC2 instances in the same VPC as Memcached instances. Each instance of Memcached received an identical load based on the parameters below.
Figure 3: Performance benchmarking test setup
Following input parameters were used while performing the benchmarking tests on R5 and R6g EC2 instances.
Input parameter  Value
Number of threads  5
Number of clients per thread  100
Number of requests per client   10k
Number of consecutive tests runs  20
Key size  16
Data size  128
Memcached protocol text
Key pattern  random
Table 1 Input parameters for benchmarking tests
Each test run generates 5 threads with 100 clients per thread, which gives 500 simultaneous connections (sessions). That adds up to 5 million number of requests sent each run from Memtier. The results in Table 1 show throughput (Operations/Sec) and latency (lower is better) values.
Instance type Operations/Sec p50 Latency (ms) p99 Latency (ms)
r5.2xlarge 261803.93 1.511 3.215
r6g.2xlarge 394734.65 1.271 2.799
Performance Gain (%) 50.77% 15.88% 12.93%
Table 2 Memcached performance results on R5 vs R6g
Configurations
Following are the pre-requisites to build the test setup.
Component name Version
Memcached 1.6.6
Memtier benchmark tool 1.3.0
Operating System Ubuntu 20.10
Memcached 1.6.6 requires Ubuntu 20.10 and may not be installed via the APT repository. Download the binary file (arm64 and x86_84) manually and then install it on respective EC2 instances (R6g and R5). Follow the steps mentioned here to install the Memtier benchmarking tool.
A sample input command to execute the Memtier tests is mentioned in the following command:
memtier_benchmark -s <Memcache_IP_address> -p 11211 --protocol=memcache_text --clients=100 --threads=5 --ratio=1:1 --key-pattern=R:R --key-minimum=16 --key-maximum=16 --data-size=128 --requests=10000 --run-count=20
CPU utilization metrics for R5 and R6g instances
While executing the benchmarking tests, we used Grafana to visualize the CPU utilization per core and overall CPU utilization metrics for each of the instances. Figure 4 and 5 show the utilization charts for R5 and R6g instances.
Figure 4: CPU utilization graph for R5 instances.
 Figure 5: CPU utilization graphs for R6g instances.
Deploying Memcached on AWS Graviton2 instances can provide 51% performance improvements and in addition a 20% cost benefit. Deploying new applications on AWS Graviton2 is simple and quick, allowing these gains to be realized without any complex migration requirements. For further details on getting started with AWS Graviton2, please visit this github page.
Feel free to reach out to us on sw-ecosystem@arm.com with any inquires related to running your software workloads on Arm Neoverse platforms.
  • Martin Grigorov
    Martin Grigorov over 4 years ago
    Check my findings from several months back: https://martin-grigorov.medium.com/compare-memcached-performance-on-x86-64-and-arm64-cpu-architectures-7fe781e34ab8 Memtier is not a good tool to load test Memcached. Better use github.com/.../mc-crusher
    Marc Meunier
    Marc Meunier
    • October 2, 2025
    Na Li
    Na Li
    • October 1, 2025
  • Redefining storage with Arm Cortex-R82 and Neoverse CMN-S3
    John Xavier Lionel
    John Xavier Lionel
    Explore how Cortex-R82 and CMN-S3 enable secure, reliable, and scalable storage architectures for the future.
    • September 30, 2025
