In late 2014, Carbon released the first Carbon Performance Analysis Kit (CPAK) utilizing the ARM CoreLink CCN-504 Cache Coherent Network. Today, the CCN-504 can be built on Carbon IP Exchange with a wide range of configuration options. There are now four CPAKs utilizing the CCN-504 on Carbon System Exchange. The largest design includes sixteen Cortex-A57 processors, the most processors ever included in a Carbon CPAK.
At the same time SoC Designer has added new AMBA 5 CHI features including support for monitors, breakpoints, Carbon Analyzer support, and a CHI stub component for testing.
To get a good introduction on AMBA 5 CHI I recommend the article, "What is AMBA 5 CHI and how does it help?".
Another interesting ARM Community article is “5 things you might now know about AMBA 5 CHI”.
Although the cache coherency builds on AMBA 4 ACE and is likely familiar, some of the aspects of CHI are quite different.
Configuring the CCN-504 on Carbon IP Exchange is similar to all Carbon models. Select the desired interface types, node population, and other hardware details and click the "Build It" button to compile a model.
One of the challenges of configuring CHI systems is to make sure the System Address Map (SAM) is correctly defined. As indicated in the table above, the process is more complex compared to a simple memory map with address ranges assigned to ports.
The network layer of the protocol is responsible for routing packets between nodes. Recall from the previous article that CHI is a layered protocol consisting of nodes of various types. Each node has a unique Network ID and each packet specifies a Target ID to send the packet to and a Source ID to be able to route the response.
For a system with A57 CPUs and a CCN-504 each Request Node (RN), such as a CPU, has a System Address Map (SAM) which is used to determine where to send packets. There are three possible node types a message could be sent to: Miscellaneous Node (MN), Home Node I/O coherent (HN-I), or Home Node Fully coherent (HN-F). DVM and Barrier messages are always sent to the MN so the challenge is to determine which of the possible Home Nodes an address is destined for.
The make the calculation of which HN-F is targeted the RN uses an address hash function. This can be found in the CCN-504 TRM.
Each CCN has a different hashing function depending on how many HN-F partitions are being used.
The hashing function calculates the HN-F to be used, but this is still not a Network ID. Additional configuration signals provide the mapping from HN-F number to Node ID.
All of this means there are a number of SAM* parameters for the A57 and the CCN-504 which must be set correctly for the memory map to function. It also means that a debugging tool which makes use of back-door memory access needs to understand the hashing function to know where to find the correct data for a given address. SoC Designer takes all of this into consideration to provide system debugging.
As you can see, setting up a working memory map is more complex compared to routing addresses to ports.
Carbon models use configuration parameters to perform the following tasks:
The parameters for the A57 CPU model are shown below:
The parameters for the CCN-504 model are similar, a list of SAMADDRMAP* values and SAM*NODEID values.
It’s key to make sure the parameters are correctly set for the system to function properly.
Sometimes it’s helpful to have a picture of all of the parts of a CCN system. The cheat sheet below has been a tremendous help for Carbon engineers to keep track of the node types and node id values in a system.
With the introduction of AMBA 5 CHI, SoC Designer has been enhanced to provide CHI breakpoints, monitors, and profiling information.
Screenshots of CHI transactions and CHI profiling are shown below. The Target ID and the Source ID for each transaction are shown. This is from the single-core A57 CPAK so the SourceID values are always 1. Multi-core CPAKs will create transactions with different SourceID values.
The CCN-504 has a large number of PMU events which can be used to understand performance.
AMBA 5 CHI is targeted at systems with larger numbers of coherent masters. The AMBA 5 CHI system memory map is more complex compared to ACE systems. A number of System Address Map parameters are required to build a working system, both for the CPU and for the interconnect.
Carbon SoC Designer is a great way to experiment and learn how CHI systems work. Pre-configured Carbon Performance Analysis Kits (CPAKs) are available on Carbon System Exchange which can be downloaded and run which demonstrate hardware configuration as well as the software programming needed to initialize a CHI system. Just like the address map, the initialization software is more complex compared to an ACE system with a CCI-400 or CCI-500.
