SoC Design and Simulation blog Cadence's New Digital Implementation System: An Inside Look
  • semiconductor
  • and
  • cadence
  • Timing
  • design
  • encounter
  • edi
  • implementation
  • route
  • optimization
  • soc
  • place
  • innovus
  • digital
Brian Fuller
Brian Fuller
March 17, 2015
3 minute read time.
SANTA CLARA, Calif.—The launch of Cadence's new Innovus Implementation System heralds “a new era” in physical implementation technology, breaking longstanding electronic system-design bottlenecks, according to Rahul Deokar, product management director with Cadence.
Deokar gave a technical overview of the new technology at CDNLive Silicon Valley, just hours after it was unveiled during a keynote address at the annual event (March 10). “Older implementation tools had forced you guys as designers to do smaller design blocks,” he told a standing room-only audience at the Santa Clara Convention Center here. “You can now handle 5-10 million instance design blocks…and you can take weeks or even months off your SoC design schedules.”Slide06.jpg
Leapfrog Effect
Against the backdrop of SoC Implementation, the new technology represents a fundamental overhaul of the Encounter system that “leapfrogs” the industry and delivers a far more compelling digital implementation solution than the industry has experienced, Deokar said.
Previously, optimizing for power, performance and area (PPA) and improving turn-around time (TAT) was an either-or choice, he said.
"These were two conflicting objectives in a lot of ways. Traditional tools have effectively tackled just one or the other, however what good is it if the tool runs super-fast but ends up with sub-optimal PPA,” Deokar said. “Innovus gets you the best of both worlds on TAT and PPA.”
By delivering performance that is up to10x faster, design blocks that took 7-10 days can now be run in 1-2 days. The 10-20 percent PPA improvement is equivalent to a half-node or even a full-node transition, without actually moving to the new node, he added.
Furthermore, because the technology is integrated with Cadence signoff solutions, significant additional productivity gains can be achieved along the flow, he added.
And Innovus is not targeted at just bleeding-edge nodes such as 16/14/10nm; it has vast utility for established process nodes as well, Deokar said.
Driving improved TAT
A massively parallel architecture is key to improved turn-around time, Deokar said. The core algorithms have been improved such that “even if you're not running on 16 or 32 or 64 CPUs, the core algorithms of placement, optimization and routing have been sped up. Even on 2- and 4-CPU machines, you should be able to see TAT advantages,” he said. “Now, add multithreading, distributed network processing and MMMC (multi-mode/multi-corner) scenario acceleration, and you get the complete massively parallel system.”
That means really large chips that forced teams to divide the SoC into many blocks to manage the placement and routing complexities can now work with fewer blocks, which cuts design time and saves money, Deokar said.
He cited as one example a 28nm 2.8 million-cell networking IP running on 8 CPUs (pictured) that saw implementation time cut from 336 hours to 48 hours—a 7x improvement.
Slide12.jpgPushing PPA
The other key Innovus benefit for PPA represents a big step forward, he said.
Traditionally, placement ran on heuristic-based algorithms, but GigaPlace in Innovus is solver- or equation-based.
“That means you can model in the equation a lot of different design variables - timing, slack, power, wire length, congestion, layer awareness,” Deokar said. “GigaPlace concurrently solves both the electrical and physical objectives. As a result you get better PPA.”
Another feature is that Innovus is now power aware throughout the optimization process, Deokar said.
“All the transforms that were timing and area aware, now power is a part of that same cost function,” he told his audience.
A third key component is that the concurrent clock and datapath optimization technology from Azuro, which Cadence acquired in 2011, is now fully integrated.
“A lot high-performance designers have unique clocking methodologies -- H-trees, clock meshes, multipoint CTS,” he said. “You guys invest a lot of manual effort building these, but since these are customized, they’re not flexible when process and technology changes occur.”
The CCOopt FlexH feature integrated into Innovus is a combination of regular clock tree and H-tree, he said, “You get the best of both worlds in automation and in cross-corner variation, as well as in high-performance and a power-efficient clock network.”
Deokar also highlighted the track-aware optimization features of NanoRoute.
“Before you go into your detailed route step, right after track assignment to the different metals layers, we do timing-aware optimization,” Deokar said. “This pro-actively prevents signal integrity issues from occurring downstream in the flow, and dramatically reduces the timing jump between pre route and post route optimization.”
Finally Deokar noted productivity gains from the integration of Innovus with existing Cadence signoff technologies such as Tempus, Voltus and Quantus, a common user interface and reporting and visualization enhancements.
More information about Innovus can be found by navigating to the technology's landing page.
    Tony Nip
    Tony Nip
    • June 30, 2025
    Vincent Yang
    Vincent Yang
    • June 5, 2024
  • Introduction to AMBA Viz
    Tony Nip
    Tony Nip
    • May 31, 2024
