Servers and Cloud Computing blog Building a Serverless Platform on Arm64
  • Open Source Projects
  • containers
  • Cloud Native
Howard Zhang
Howard Zhang
May 16, 2023
12 minute read time.
This is an introduction of how we deploy a Serverless Platform with multiple runtimes on an Arm64 server, after which we conclude with container runtimes and Wasm with some performance evaluation. Hopefully, you can have some general idea on Serverless and how these cloud-native projects work on Arm64 servers.
In this blog, we explain:
  • An overview of Serverless
  • Serverless on Arm
    • Deployment
    • Kubernetes with WasmEdge
  • User cases
    • ChatBot
    • More useful features
      • Autoscaling
      • Traffic Split
      • Flows
      • Eventing triggering
  • Summary
According to the CNCF (Cloud Native Computing Foundation) Cloud Native Survey 2020 and 2021 surveys, 30% of respondents (2020) and 39% of respondents (2021) use Serverless technologies in production. Serverless has become widely accepted by users and has become a hot topic on cloud computing.
Serverless does not mean there is no server. It is more like a metaphor, as server-side work, like provisioning, maintaining and scaling the server infrastructure, is done by the cloud provider. Customers or developers cannot perceive the server.
It is based on Microservice. Developers can submit the code of their application. Then Serverless services would do following works
  1. Compile the application code
  2. Build an image
  3. Deploy the application
  4. Setup network
  5. Auto-generate a web accessible API for the application
The application can make use of various third-party services that is BaaS, like authentication service, cloud-accessible databases, encryption . In addition, Serverless services usually support event-triggered models. Applications are launched only as needed. When an event triggers application code to run, the cloud provider dynamically allocates resources for the code. Most cloud providers have their own Serverless service, like AWS Lambda, Azure Functions, Google Cloud Functions.
Serverless provides some benefits:
  • Lower complexity and less DevOps work.
  • Pay as you go: Pay just for executions’ accumulated time. And lower costs compared to traditional setup.
  • Faster development: less configuration is needed.
  • Flexibility: Serverless models auto scale without customers’ intervention.
  • Self-maintenance: Clients do not need to perform server maintenance.
But there are also some drawbacks of Serverless:
  • Slow cold starts
  • High latency
  • Hard to debug
  • Data synchronization is a problem.
These pros and cons make Serverless suitable for stateless, ephemeral, async, parallel workloads. For example, processing data at scale, running interactive web and mobile backends and enabling powerful ML (Machine Learning) insights can be setup as serverless services.
You can find some useful resources about Serverless in the Reference section.
Serverless on Arm
We deployed a Serverless platform on Arm64 server and here is the basic information about the platform.
CPU   AmpereTM AltraTM Processor
Linux kernel   5.17.0
Kubernetes  v1.25.0
Knative  v1.7.1
The following image is the architecture of this Serverless Platform, it contains three layers:
  • Knative
  • Kubernetes
  • Runtimes
 Serverless Platform Architecture
Let us start with the mid-layer, Kubernetes. Kubernetes is an open-source system for automating the deployment, scaling, and management of containerized applications. It groups containers that make up an application into logical units for easy management and discovery. With its help, we can easily deploy a cluster that can manage resources of hundreds of servers and run container workload on the cluster. It can also integrate with Container Network Interface (CNI) and Container Storage Interface (CSI) to manage the network and storage.
Knative is an open-source Enterprise-level solution to build Serverless and event-driven applications. Knative integrates Kubernetes, service mesh, message channel and broker, and some other extensions. It puts the serverless concept into practice. It contains two primary components:
  • Serving: Enables rapid deployment and automatic scaling of containers through a request-driven model for serving workloads based on demand.
  • Eventing: An infrastructure for consuming and producing events to stimulate apps. Apps can be triggered by various sources, such as events from your own apps, and cloud services from multiple providers.
Despite the Runc runtime that is supported by default, we integrated another three runtimes into this platform, which are Kata container, gVisor, and WasmEdge. Each runtime has its own adapted areas, like lightweight applications, and a Secure environment. Integrating these runtimes into the serverless platform allows us to have more fixable and well-rounded choices when deploying our application.
Deployment example using Kubernetes with Kata and Knative
Please refer to the official guide to install Kata container, Knative, and Kubernetes. Here we explain more details on how to integrate WasmEdge with Kubernetes
https://kubernetes.io/docs/setup/production-environment/tools/kubeadm/create-cluster-kubeadm/
https://github.com/kata-containers/kata-containers/tree/main/docs/install
https://knative.dev/docs/install/
  1. Compile crun
  2. Setting containerd to support crun runtime
  3. Add crun runtime into the Kubernetes cluster
Compile Crun
The crun project has WasmEdge support baked in. We need to compile it by ourselves.
# Install dependencies
$ sudo apt update
$ sudo apt install -y make git gcc build-essential pkgconf libtool \
    libsystemd-dev libprotobuf-c-dev libcap-dev libseccomp-dev libyajl-dev \
    go-md2man libtool autoconf python3 automake
# Compile crun
$ git clone https://github.com/containers/crun
$ cd crun
$ ./autogen.sh
$ ./configure --with-wasmedge
$ make
$ sudo make install
Setting Containerd
Add the following lines to /etc/containerd/config.toml to enable crun runtime.
[plugins]
        [plugins.cri.containerd.runtimes.crun]
           runtime_type = "io.containerd.runc.v2"
           pod_annotations = ["*.wasm.*", "wasm.*", "module.wasm.image/*", "*.module.wasm.image", "module.wasm.image/variant.*"]
           privileged_without_host_devices = false
           [plugins.cri.containerd.runtimes.crun.options]
             BinaryName = "/usr/local/bin/crun"
# restart containerd
$ sudo systemctl restart containerd
Add Crun Runtime to Kubernetes Cluster
$ cat > runtime.yaml <<EOF
apiVersion: node.k8s.io/v1
kind: RuntimeClass
metadata:
handler: crun
EOF
kubectl apply runtime.yaml
# Verify
$ kubectl run -it --rm --restart=Never wasi-demo --image=wasmedge/example-wasi:latest --annotations="module.wasm.image/variant=compat-smart" --overrides='{"kind":"Pod", "apiVersion":"v1", "spec": {"hostNetwork": true, "runtimeClassName": "crun"}}' /wasi_example_main.wasm 50000000
Random number: 1534679888
Random bytes: [88, 170, 82, 181, 231, 47, 31, 34, 195, 243, 134, 247, 211, 145, 28, 30, 162, 127, 234, 208, 213, 192, 205, 141, 83, 161, 121, 206, 214, 163, 196, 141, 158, 96, 137, 151, 49, 172, 88, 234, 195, 137, 44, 152, 7, 130, 41, 33, 85, 144, 197, 25, 104, 236, 201, 91, 210, 17, 59, 248, 80, 164, 19, 10, 46, 116, 182, 111, 112, 239, 140, 16, 6, 249, 89, 176, 55, 6, 41, 62, 236, 132, 72, 70, 170, 7, 248, 176, 209, 218, 214, 160, 110, 93, 232, 175, 124, 199, 33, 144, 2, 147, 219, 236, 255, 95, 47, 15, 95, 192, 239, 63, 157, 103, 250, 200, 85, 237, 44, 119, 98, 211, 163, 26, 157, 248, 24, 0]
Printed from wasi: This is from a main function
The env vars are as follows.
The args are as follows.
50000000
File content is This is in a file
pod "wasi-demo" deleted
# open runtime class feature gate in knative
$ kubectl patch configmap/config-features -n knative-serving --type merge --patch '{"data":{"kubernetes.podspec-runtimeclassname":"enabled"}}'
User cases
Chat Bot
Chat Bot is a good user case for the Serverless platform as its workload is unpredictable and it is a serverless service.
Here we write a chat bot service which includes frontend and backend. We can choose the desired runtime to run the service. The source code can be found in the branch backend and frontend in https://github.com/zhlhahaha/flask-chatterbot.
Setup the DNS
Setup dns and make sure we can visit the serverless services via call dns directly. Here is the official guide https://knative.dev/docs/install/yaml-install/serving/install-serving-with-yaml/#configure-dns.
We use dnsmasq to set DNS directly.
// add externel ip for kourier
$ kubectl edit services -n kourier-system kourier
spec:
  allocateLoadBalancerNodePorts: true
  clusterIP: 10.105.58.134
  clusterIPs:
  - 10.105.58.134
  externalIPs:
  - 192.168.100.100
  externalTrafficPolicy: Cluster
  internalTrafficPolicy: Cluster
// config the dnsmasq
$ cat /etc/NetworkManager/NetworkManager.conf
[main]
plugins=ifupdown,keyfile
dns=dnsmasq
[ifupdown]
managed=false
[device]
wifi.scan-rand-mac-address=no
$ sudo rm /etc/resolv.conf ; sudo ln -s /var/run/NetworkManager/resolv.conf /etc/resolv.conf
$ echo 'address=/.knative.example.com/192.168.100.10' | sudo tee /etc/NetworkManager/dnsmasq.d/knative.example.com-wildcard.conf
$ sudo systemctl reload NetworkManager
// verify if dnsmasq works
$ dig knative.example.com +short
192.168.100.100
// setup the auto-generate serverless service url
$ kubectl patch configmap/config-domain \
  --namespace knative-serving \
  --type merge \
  --patch '{"data":{"knative.example.com":""}}'
Deploy Chatbot Serverless Services
Here we deploy three serverless services for runc, gVisor, and Kata. It will auto generate three URLs as follows.
$ kubectl apply -f services.yaml
$ cat services.yaml
apiVersion: serving.knative.dev/v1
kind: Service
metadata:
spec:
  template:
    spec:
      timeoutSeconds: 10
      containers:
      - image: zhlhahaha/flask-chatterbot:runc
        command: ['python', 'app.py']
        ports:
        - containerPort: 5000
kind: Service
metadata:
spec:
  template:
    spec:
      runtimeClassName: gvisor
      timeoutSeconds: 10
      containers:
      - image: zhlhahaha/flask-chatterbot:gvisor
        ports:
kind: Service
metadata:
spec:
  template:
    spec:
      runtimeClassName: kata
      timeoutSeconds: 10
      containers:
      - image: zhlhahaha/flask-chatterbot:kata
        ports:
$ kubectl get ksvc
NAME                   URL                                                       LATESTCREATED                LATESTREADY                  READY   REASON
chatterbot-gvisor      http://chatterbot-gvisor.default.knative.example.com      chatterbot-gvisor-00001      chatterbot-gvisor-00001      True
chatterbot-kata        http://chatterbot-kata.default.knative.example.com        chatterbot-kata-00001        chatterbot-kata-00001        True
chatterbot-runc        http://chatterbot-runc.default.knative.example.com        chatterbot-runc-00001        chatterbot-runc-00001        True
// verify if the services works
$ curl http://chatterbot-runc.default.knative.example.com/version
version1
Start Front End
As the dnsmasq only works for local environment, the frontend service and web browser are supposed to run in the same machine with Serverless backend server.
// start the frontend service
$ git clone https://github.com/zhlhahaha/flask-chatterbot
$ git checkout frontend
$ pip install requirements.txt
$ python app.py
 * Serving Flask app "app" (lazy loading)
 * Environment: production
   WARNING: This is a development server. Do not use it in a production deployment.
   Use a production WSGI server instead.
 * Debug mode: off
 * Running on http://0.0.0.0:5000/ (Press CTRL+C to quit)
// Use web brower to visit the web page.
$ chromium-browser --no-sandbox
// visit the webpage
http://localhost:5000
Here is an demo of the Serverless Platform on Arm64:
All these features have been verified on the Arm64 Serverless platform.
Autoscaling
Autoscaling allows the cluster dynamically adjusts the number of pods according to the load. For example, if the amount of service requests is getting larger, Knative would auto scale up the number of service pods to manage requests. As Knative has integrated with autoscaling service, we can just setup the autoscaling rules in the service config file. Here is an example to show you how simple it is.
    metadata:
      annotations:
        # Knative concurrency-based autoscaling (default).
        autoscaling.knative.dev/class: kpa.autoscaling.knative.dev
        autoscaling.knative.dev/metric: concurrency
        # Target 10 requests in-flight per pod.
        autoscaling.knative.dev/target: "10"
As you can see in the previous configuration, and when the number of requests goes to a service pod is larger than 10, it will auto create a pod to handle requests. Also, Knative support scale down to 0, which means there are no resources consumed when no request comes.
Traffic Split
As Knative uses service mesh to manage the network, it allows Knative to have more precise traffic control. Traffic splitting is useful for blue/green deployments and canary deployments. Each time we update a serverless service, the service would have version tags. And we can split traffic to a different version of the service. In the following case, the chatterbot service has two revisions, and we can split 70% of traffic to chatterbot-00001 and 30% of traffic to chatterbot-00002.
$ kubectl get revisions
NAME                         CONFIG NAME            K8S SERVICE NAME   GENERATION   READY   REASON   ACTUAL REPLICAS   DESIRED REPLICAS
chatterbot-00001             chatterbot                                1            True             0                 0
chatterbot-00002             chatterbot                                2            True             0                 0
// then we can split traffic to different revision of chatterbot
 traffic:
    - tag: current
      revisionName: chatterbot-00001
      percent: 70
    - tag: latest
      revisionName: chatterbot-00002
      percent: 30
Without the Knative, developers need a wide range of networking knowledge and complex setup to make traffic split work.
Flows
Flows allow users to compose several services into a sequence or compose several sequences into a series in an easy way like the following images.
Knative diagram
 knative sequence serial
Here is the configuration for a sequence flow. We put the three Knative services into a sequence, first-runc, second-kata, and third-wasm. The output of the first service would be the input for the second service. And the same thing happens for the second service and third service.
apiVersion: flows.knative.dev/v1
kind: Sequence
metadata:
spec:
  channelTemplate:
    apiVersion: messaging.knative.dev/v1
    kind: InMemoryChannel
  steps:
    - ref:
        kind: Service
    - ref:
        kind: Service
    - ref:
        kind: Service
  reply:
    ref:
      kind: Service
Besides the sequence's tasks, it also has parallel tasks. We can split the service into different branches, and once the flow is called. Branches would parallelly run.
Eventing triggering
Knative Eventing provides you with helpful tools that can be used to create event-driven applications, by easily attaching event sources, triggers, and other options to your Knative Services.
For more details, you can refer to https://knative.dev/docs/getting-started/getting-started-eventing/
This blog introduces Serverless and its status. Serverless technology does facilitate software deployment and becomes increasingly wildly accepted by customers. We also show how to deploy a Serverless platform on Arm64 server. The platform integrates with multiple container runtimes. As different runtimes have their own specialized area, customers can choose the most appropriate runtime based on their application. In the end, we show some useful practices on the Serverless platform. Developers could easily build the Serverless framework using open-source components which are readily available on Arm platform.
References
CNCF cloud native survey 2020 - https://www.cncf.io/reports/cloud-native-survey-2020/
CNCF cloud native survey 2021 - https://www.cncf.io/wp-content/uploads/2022/02/CNCF-AR_FINAL-edits-15.2.21.pdf
Use Kubeadm create a Kubernetes cluster - https://kubernetes.io/docs/setup/production-environment/tools/kubeadm/create-cluster-kubeadm/
Kata container deployment - https://github.com/kata-containers/kata-containers/tree/main/docs/install
Knative deployment - https://knative.dev/docs/install/
Knative Eventing - https://knative.dev/docs/getting-started/getting-started-eventing/
What is Serverless - https://www.redhat.com/en/topics/cloud-native-apps/what-is-serverless
    Zongyao Zhang
    Zongyao Zhang
    • October 16, 2025
    Marc Meunier
    Marc Meunier
    • October 13, 2025
    odinlmshen
    odinlmshen
    • October 13, 2025
