Servers and Cloud Computing blog AWS Graviton4 demonstrates leading performance for HPC
  • Cloud Computing
  • Graviton
  • Server and HPC
David Lecomber
David Lecomber
July 31, 2024
4 minute read time.
The AWS Graviton4 CPU, built using the Arm Neoverse V2 core and Coherent Mesh Network (CMN-700), is now generally available. The first availability of Graviton4 is in the Amazon EC2 R8g instance family, which targets for memory-intensive workloads, such as large in-memory databases and big data analytics. Arm is evaluating R8g for our in house EDA workloads and have found that their improved performance and memory capabilities further reinforce the benefits of our migration of high performance engineering workloads to the Arm architecture.
The Graviton4 marks a significant leap forward in capability compared to its predecessor targeted at HPC, the Graviton3E, and we want to see how this performs in practice.
  AWS Graviton3E AWS Graviton4
Core Arm Neoverse V1 Arm Neoverse V2
SIMD 4x128b Neon or 2x256b SVE 4x128b Neon or 4x128b SVE2
Frequency 2.6GHz 2.7GHz (192c) / 2.8GHz (96c)
vCPU per socket1 64 96
Max sockets per instance 1 2
Max total vCPU per instance 64 192
Memory channels per socket 8 x DDR5-4800 12 x DDR5-5600
L2 Cache/vCPU 1MB per core 2MB per core
SLC Cache 32MB per socket 36MB per socket
Each AWS Graviton vCPU is a full core.
Much of HPC application performance is a memory-bandwidth story, and as the specification table shows, the Graviton4 moves the dial significantly with 16.7% more main-memory bandwidth per core, and a doubling of L2 cache per vCPU which is enabled by the Arm Neoverse V2 core.
In this first blog on the platform, we will examine workloads from a number of HPC domains:
  • Molecular Dynamics (domain): LAMMPS (workload)
  • Geosciences: SW4Lite
  • CFD: OpenFOAM
  • Cryo-EM: Relion
  • Weather: WRF
Improvement from AWS Graviton3E to AWS Graviton4
Using AWS Graviton3e (hpc7g.16xlarge) and AWS Graviton4 (r8g.24xlarge) single socket instances we compare improvement between the two generations of CPU.
While demonstrating the improvement in per-core performance, we caveat that the difference in core (vCPU) count between AWS Graviton3E (64-core) and AWS Graviton4 (96-core) prevents a perfect comparison. Higher core counts can introduce scaling inefficiency due to the testcase being distributed into smaller chunks which may mean higher overheads than running on lower core counts.
Nonetheless, our first chart shows the benchmarks as performance per core (total performance divided by number of cores), as this lets us account for the different number of cores per instance.
AWS Graviton3E is on Rocky Linux 9, and AWS Graviton 4 is on Ubuntu 22.04.  Performance is shown as best-of across GNU 13.2 and Arm Compiler for Linux 24.04 – and across the range of MxN (M MPI tasks x N OpenMP), and Open MPI 5.0 and MPICH 4.1, all compiled using Spack (https://github.com/spack/spack) (develop branch, 2024-07).
HPC Workload Comparison Graviton3E to Graviton4
The geomean across this set of workloads gives AWS Graviton4 a +24% per vCPU performance advantage over AWS Graviton3E.
Some of these performance improvements could be anticipated – such as OpenFOAM which, as a CFD application, is widely known to be memory bound and is sure to benefit from ~17% more memory bandwidth per vCPU.
Where our high expectations were exceeded, however, is on the LAMMPS and Relion tests – both compute-bound applications. LAMMPS improves by 32% and Relion by 41%. This suggests that, addition to the 7.5% faster clock speed and memory bandwidth improvements of AWS Graviton4, the micro-architecture enhancements made to our Neoverse V2 core have outsized benefits for some workloads.
WRF includes both memory-bound and compute-bound regions, and shows a healthy 24% boost per vCPU from AWS Graviton4.
Dual socket AWS Graviton4 performance relative to 4th Generation AMD EPYC
As both 4th Gen AMD EPYC (“Genoa”) and AWS Graviton4 are available as 192-vCPU instances in AWS, we can do an exact comparison between the two.
We use a c7a.48xlarge – which is a dual-socket 192-vCPU AMD EPYC, and r8g.48xlarge which is the dual-socket 192-vCPU AWS Graviton4. Worth noting, unlike previous generations of AMD EPYC instances (ex, c6a), every vCPU on a c7a instance is a physical CPU core.
4th-gen AMD EPYC-based c7a instances have 7.5% less memory bandwidth per core - due to supporting DDR5-5200 - compared to Graviton4-based r8g instances which use DDR5-5600, and smaller L2 cache, but on the other hand benefits from a larger L3 cache.
As before, we used the best results from AMD’s AOCC, Intel One compiler, and GCC, with Spack as the build system.
HPC Workload Comparison 4th Gen EYPC to Graviton4
Across the majority of our HPC workloads, on a like-for-like 192-core basis, it can be seen that AWS Graviton4 often delivers significantly better performance than the latest 4th-Gen AMD EPYC (“Genoa”)-based instances – with the geomean giving AWS Graviton4 a 15.2% advantage.
We are very excited about the general availability of AWS Graviton4 CPUs and would like to congratulate the teams at Amazon and Annapurna Labs on this achievement. As an early adopter of Arm Neoverse cores in AWS Graviton CPUs, AWS has systematically improved the capabilities of Graviton – releasing an incredible four new generations over five years, each with greater performance and capabilities to address the full spectrum of cloud workloads. In addition, Graviton4 is the most powerful and power-efficient chip AWS has ever built. We look forward to the continued pace of innovation of AWS Graviton and the positive impact each generation brings to performance and sustainable efficiency. While AI promises to bring transformation benefits across industries, for this to happen customers everywhere need to improve the efficiency of their core compute.
More Neoverse Blogs
  • David Lecomber
    David Lecomber 8 months ago
    The benchmarking compilation using the Spack recipe for WRF on both x86 and aarch64 platforms.  If you've not used Spack before, you can read more about this here: https://spack.io - this took care of all the library dependencies, and has all the recent best-practice compilation flags.
    The specific settings for both platforms was to have a build type of dm+sm, and with netcdf_classic enabled.  Spack-wise: 'spack install build_type=dm+sm +netcdf_classic' was all we need to do.
    Choice of MPI (Open MPi or MPICH) made very little difference.  We found a slight preference (single digits percent) from using Arm Compiler for Linux over GCC.
    There is also a blog on WRF from earlier -  Bringing WRF up to speed with Arm Neoverse - this links to more direct instructions for building, if you want to build manually.
  • Weather Risk
    Weather Risk 8 months ago
    These test results are truly impressive.
    Would it be possible for you to provide documentation on compiling various libraries using in WRF?
    Marc Meunier
    Marc Meunier
    • October 13, 2025
    odinlmshen
    odinlmshen
    • October 13, 2025
    odinlmshen
    odinlmshen
    • October 13, 2025
