Users of Performance Advisor can create custom reports which allow them to tailor the data they see in their report to their exact requirements. In the latest release of Arm Streamline, part of Arm Performance Studio 2024.0, we have introduced several new features to custom reporting. These changes allow you a finer degree of control over what you can see in your reports.
Note: this content assumes a working knowledge of Performance Advisor, and its existing custom reporting features. The existing features are still present. You can still make custom reports this way if required.
The most notable addition to custom reporting is the ability to specify series to show on a particular chart. Previously in a custom report, you could choose any chart from Streamline and have this displayed in PA. However, this meant the Performance Advisor chart contained every series from the Streamline chart. Now, you can include specific series from any chart you like by identifying them by their corresponding expression name. The expression name is found in the chart configuration panel in Streamline
To build a custom report, create a JSON file which can be named and located as you wish. You will need to include this file later when generating the performance report. Below is an example of a custom report, featuring a chart titled “GPU cycles per frame” defined in the new format:
{ "groups": [ { "title": "Group 1", "charts": [ { "id": "gpuUsagePerFrame", "title": "GPU cycles per frame", "series": [ { "title": "GPU cycles", "expression": "$MaliGPUCyclesGPUActive" }, { "title": "Fragment cycles", "expression": "$MaliGPUCyclesFragmentQueueActive" }, { "title": "Non-fragment cycles", "expression": "$MaliGPUCyclesNonFragmentQueueActive" } ], "description": "This chart shows GPU cycles per frame.", "units": "Cycles" } ] } ] }
If you are familiar with the old layout of custom report files, you can see the layout is largely the same. Parameters such as “description” and “units” are unchanged. However, instead of defining a chart from its name in Streamline, you can pass an array of series defined by their corresponding expression. The series also has a title, which is shown on the axis of the chart in the report. Both the “expression” and “title” properties must be included. Because you are now able to provide individual series directly to charts, you are no longer limited to showing entire existing charts from Streamline. You can now create a custom PA chart featuring series from multiple Streamline charts. Allowing you to group data together as you see fit.
The Streamline expression language used by Performance Advisor can understand some basic arithmetic, including:
This means you can perform operations on data similarly to how Performance Advisor does in its "standard" charts. This allows an even greater degree of control over the data you show.
We have a capture of an application made on a device with a Mali-G71 GPU. We want to see a chart showing the number of shader cycles per shader core count per frame. We will easily create a custom chart to show this.
First, we would need to find each of the cycles we are interested in in Streamline, in this example these would be:
Once we have the series we wish to show, we copy its corresponding expression from the expression box in the Streamline chart's configuration panel:
Once we have these expressions, we can make this data per shader core count by using $MaliConstantsShaderCoreCount and dividing our counter expressions by it in our series definition.
Now we would create a chart element in our custom report JSON file and add the counter expressions and the division arithmetic:
{ "id": "shaderCoreBifrostPerFrame", "title": "Shader cycles per frame", "series": [ { "title": "Execution engine cycles", "expression": "($MaliALUInstructionsExecutedInstructions) / $MaliConstantsShaderCoreCount" }, { "title": "Load/store cycles", "expression": "($MaliLoadStoreUnitCyclesFullRead + $MaliLoadStoreUnitCyclesPartialRead + $MaliLoadStoreUnitCyclesFullWrite + $MaliLoadStoreUnitCyclesPartialWrite + $MaliLoadStoreUnitCyclesAtomicAccess) / $MaliConstantsShaderCoreCount" }, { "title": "Varying Cycles", "expression": "(($MaliVaryingUnitIssues16BitInterpolationIssues) + ($MaliVaryingUnitIssues32BitInterpolationIssues)) / $MaliConstantsShaderCoreCount" }, { "title": "Texture cycles", "expression": "($MaliTextureUnitCyclesFilteringActive) / $MaliConstantsShaderCoreCount" } ], "description": "This chart shows the absolute number of shader cycles per frame for each pipeline.", "units": "Cycles" }
Then, when we generate the report, we include our custom report with –custom-report=<path to custom report JSON file> We would get an output chart like this:
The series object in the custom report has a few more optional parameters that can be set for specific cases.
Here is an example of a chart with some of the additional parameters:
{ "id": "drawCallsPerFrame", "title": "Draw calls per frame", "series": [ { "title": "Draw calls", "expression": "$DrawCallsFrameVkDevice0xe7438000", "isMax": "true", "isPerFrame": "true" } ], "description": "This chart shows the draw calls per frame.", "units": "Draw calls" }
With these additions, you now have much more control over the charts you can create in a Performance Advisor report. If you like what you have seen here, please try it out and let us know what you think. To learn more about Performance Advisor, please refer to the user guide.
Download Arm Performance Studio
